How do you convert in/lbs to ft/lbs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BobK, Sep 10, 2002.
  1. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    I need to convert 144inch/lbs to foot/lbs.I don't have a tourque wrench calibrated in inch/lbs.
    How many inch/lbs in a foot/lb? /forums/images/icons/confused.gif
  2. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    12 inches in a foot. 144 inches = 12 foot lbs.
  3. TIGHTWORK82 K5
    TIGHTWORK82 K5 1/2 ton status
    Oct 21, 2001
    140
    orlando , florida
    Re: How to convert in/lbs to ft/lbs
    divide by 12
    ft lbs to inch lbs divide (144/12= 12ft lbs)
    inch lbs to ft lbs multiply (x12) /forums/images/icons/wink.gif
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Thanks guys. /forums/images/icons/grin.gif
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Your torque wrench can be off quite a bit at that low a setting.
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Wow, you guys are pretty nice. You should have seen the flaming a guy got for posting that question on the Pirate board a couple of weeks ago. /forums/images/icons/smile.gif
  7. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    I use this cause then I can't f$%& it up!
    /forums/images/icons/tongue.gif
    online conversions
  8. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    The real drawback to using a foot/lbs torque wrench in lieu of an inch/lbs wrench is that the amount it may be off is exponentially greater on a ft/lbs torque wrench as opposed to an in/lbs torque wrench. A ft/lbs torque wrench is calibrated to within "x" amount of ft/lbs, where as an in/lbs torque wrench is calibrated within "x" amount of inch/lbs. An in/lbs wrench is a much more accurate tool. Hope this helps.
    John
  9. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    That conversion site is cool. Thanks.
    John
