How do you figure concrete yardage???
Discussion in 'The Lounge' started by chevyfumes, Feb 6, 2004.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    500 sq. feet 4" thick =__________.
    Fill in the blank... /forums/images/graemlins/deal.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/dunno.gif
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    166 2/3 cubic feet or 6.17 CU yards
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    lenght X width X hieght divided by 27
  4. sapper
    Jul 11, 2001
    3,052
    NoVa
    6.17 square yards, thats from a online calc, if i put it in right, 5'x 100' does equal 500 square right???????
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep 5 x 100 is two dimensional in which is squared, would be 500 square yep
  6. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    for dlivery last i looked it was $85 a SQ CU yard in nj and a 3 yard min
  7. chevyfumes
    Feb 24, 2000
    38,584
    266
    /forums/images/graemlins/waytogo.gifThanks guy's... /forums/images/graemlins/waytogo.gif
  8. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Cost is gonna depend first on the mix your using then on the yardage.
    What is it for, drive, patio, slab, footer, wall, basement . . . you get the idea.
    Once you figure the type of mix you need then your looking at having them load 6.5 to 7 yards just to be safe.
    What does the ground look like where the truck has to go. If it's muddy you might want to split it into two loads too, it gets real expensive to pull out a stuck mixer unless you have your own equipment (most of these guys have driven for years but few of the guys around here wheel and they get stuck off road way too easy)
    Also keep in mind that you only have so much time for each yard on the truck before they start to charge extra for time too.
    That price is right around in the ballpark for most of what we do too.
    Here's a good calculator
  9. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    250 80lb Bags if you want to mix it yourself /forums/images/graemlins/yikes.gif
  10. chevyfumes
    Feb 24, 2000
    38,584
    266
    And it would only be about $100.00 more, what a deal... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  11. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    What kind of slab? You may want to thicken then edge to prvent cracking.
  12. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    Hope you know how to run the chute and give commands to the driver. Or you could hire a pump guy and his pump. That's usually about $100 for a 9 yard load or less. You will also have to tell them you want a "pump mix". The pump mix has smaller rock and is usually a little more watered down.
    Now you know where the term "The Whole Nine Yards" comes from... Even though concrete trucks will hold ten yards, they only carry 9 max so it doesn't spill out while traveling up hills. With steep hills they only carry 8 or even less if it is really steep. /forums/images/graemlins/waytogo.gif
  13. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    Cali has such small trucks /forums/images/graemlins/histerical.gif
    I ran 12 yards on a regular basis in my mixer!
    A good driver can keep it in the drum, wet, overloaded, and going up a steep hill.
    I never spilled a bit until I got rolled./forums/images/graemlins/doah.gif
    As for the pump, unless it's a trailer pump they can handle the standard mixes no problems. We use them (the big Schwing's) on a regular basis for footers and walls that we just can't safely get the mixers to. If the pump operator knows what he's doing and the guys pouring the concrete are good then it won't have to be any wetter than if you were to pour it down the chutes.
    Talk to the driver first and have him show you what hand signals he used to using and just go from there!
    Here's one of our rigs and a my first job on a pump last year.
  14. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    (500 x.33)
    --------- = 6.1 cu yards.
    27
    Forumula to figgur concrete.
    500 is the surface sq ft of the area times X .33= how thick.( 4" is .33 of a foot. 6" is .50 of a foot. 3" would be .25...... and so on)
    Divided by------
    27. The number of cu feet in a cubic yard.
  15. landsmasher
    Mar 13, 2002
    4,423
    Everything in California is small except breasts and the amount of wellfare recipients...
