how do you find the angles of a triangle when...
Discussion in 'The Lounge' started by colbystephens, Oct 11, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    you only have the three lengths of the sides? this is not a right triangle.
  2. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    Depends.
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
  4. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    on?
  5. bear76
    Oct 16, 2005
    1,065
    here
    If I know it from memory or have to figure it out. Triangle angles = 180* find the ratio of the sides to each other and divide 180* by those ratios. Ratios with 1-1-2 the angles = 45*45*90*. I'm not a teacher, that the best I can explain it.
  6. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    Sin(x)=opposite/ hypotenuse
    Cos(x)= adjacent/ hypotenuse
    Tan(x)= opp/adj
    Inverse of the above, when the appropriate lengths for the trig function are entered should give you the value of x.
    sin^-1(opp/hyp)=x
    and so on.
    Right? its been a while since trig.
  7. BigBen
    BigBen 1/2 ton status Premium Member
    Nov 14, 2002
    1,194
    Grand Haven, MI
    Correct.
  8. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    That would be it. I'm taking this damn class right now. I hate trig...........
  9. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Trig only works on right triangles, right?
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    trig doesn't only work on right triangles, but the equations posted do only work on right triangles. the only trig function i know that does work on non-right triangles is:
    a/sin(A)=b/sin(B)=c/sin(C).
  11. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
