how do you fix stripped threads?
Discussion in 'The Garage' started by colbystephens, Oct 4, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so one of the tapped holes which is used to bolt the starter to the block on my engine is stripped. how do i go about repairing it? it's working fine right now to only have one bolt holding it on there, but i don't like that. i'm not familiar w/ how to tap holes or anything of that nature. a bit o help is appreciated.
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Get a heli-coil. You drill the hole larger and tap it large then screw in a thread adapter of sorts.
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    without using a drill press, how can i assure that i'm drilling straight upwards?
  4. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    The existing hole won't let you go to far from strait.
  5. fabjunkie
    fabjunkie 1/2 ton status
    Aug 23, 2005
    1,580
    Dallas Outskirts
    Just keep the drill as straight to the block as you can. A little bit of variance won't hurt for what it is, and you only have to really worry about it at first. You can do it! All night long!
  6. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    a firm grip and eagle vision. do you have a tap and die set?
  7. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    not yet... :o
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ya got that right. :cool:
  9. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    use...
    I use a peice of round stock as a guide while drilling a hole with a hand drill,to keep it square..a hunk of 1" round stock with the size hole your drilling in it,squared off on the end,held against what your drilling, works well to keep the drill aligned properly..
    Be aware Heli-Coils use a special tap to cut the new threads it screws into--they are NOT the same as ordinary taps!..also,other similar brands of thread repair inserts do NOT use the same taps as Heli-Coils!..once you get a Heli-Coil installed,they are usually permanent repairs..
    I've seen many 6.2's JUNKED because the starter bolts loosened up,and a chunk of the block got torn out!..I'd fix yours ASAP,or it'll suffer the same demise..:eek1:
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    thanks for the tip, Diesel. in the 6.2 block, are there any oil passages that i need to be cautious of if i'm opening the hole up a bit? this is the hole on the outter passenger side.
  11. fabjunkie
    Aug 23, 2005
    1,580
    Dallas Outskirts
    I don't anything about 6.2's, but I'd think that you'd be safe on the outer hole. The Heli-Coil's will come with the tap you need to insert it.
