How do you get a hub seal out of 14bff??
Discussion in 'The Garage' started by XHitman396, Jul 21, 2006.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    Is there a trick to getting the seal that's in the inside of the hub on a 14bff out?? It's a pretty stout SOB, so is there anything better than the screwdriver and hammer way?? thanks
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    use the axle shaft to pop it out
  3. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    i flip the hub backwards on the spindle and install big 4ft prybar and pop them out all the time.:D
  4. XHitman396
    May 3, 2002
    620
    how does that work exactly??? the axle shaft that is..
  5. sweetk30
    Nov 1, 2004
    25,544
    539
    that wont work to good for you as you have non c-clip shafts. thats mostly a c-clip shaft seal trick.
  6. resurrected_jimmy
    May 23, 2005
    2,241
    substitute axle shaft for prybar as mentioned above or use it to punch the seal out with the hub off the vehicle
    another way I have done it is to pull the bearings out and then spin the nut back on the spindle a few threads and rake the hub across it to pull the seal out, kind of another form of a poor boy slide hammer
  7. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    are you doing wheel bearings or just the seal? when I did my wheel bearings all I did was lay the hub down and use a punch on the wheel bearing and it pushed the seal out with it. but I wouldnt recomend it if your not chaning wheel bearings too.
  8. sope
    sope 1/2 ton status
    Jul 8, 2005
    967
    British Columbia
    I always do it that way, even if your not changing the bearings. just make sure you have a big punch and you hit it bearing on the inside, not the cage or the rollers. I work on a fleet with lots of chev one tons and I have yet to wreck any wheel bearings this way but I have seen lots of marred up hubs from people trying to pry the seal out with screwdrivers.
