How do you get the brake calipers off of a Dana 60????
Discussion in 'The Garage' started by stallion85, Jun 25, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Damn, I feel retarded:doah:
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    You have to drive out the bendix clips to get them to come off.
    Harley
  3. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Where are those exactly?
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    They are on the caliper somewhere. I havn't delt with enough D60's to remember everything about them offhand. I have spent to long fighting the D60 trend to learn alot about them, Sorry. I have seen it done once or twice but not in a year or two now.
    Do you have a picture of the caliper from the side? I could probably help then, but someone else can probably help you too.
    Harley
  5. 86Cucvbeater
    86Cucvbeater 1/2 ton status
    May 24, 2005
    428
    north carolina
    They are on the bottom of the caliper. you need an allen key and a hammer.
  6. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    here's a couple of pictures from my question on the same topic. Hope these help a little. Now maybe someone can explain it a little better. I still really haven't played with it so I still don't know how they work
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Great thanks for the pic's:bow:
  8. mtnman210
    May 30, 2003
    3,880
    Northridge, Ca
    no problem make sure you post what you did. I still need to know how they go on:doah:
  9. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Take the only allen bolt on the caliper out, drive the clip out with a screwdriver and a hammer, and you're good to go. If the pictures already posted aren't enough I can zip a bogger off of mine if you need me to.
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    MTNman:
    You have a set of shims (things with 2 holes in them) and springs (wavy flat metal piece) there. One shim and one spring for each side (one of the shims is broken but will still work fine).
    You insert the caliper. The shim goes with the holes outside and the spring lays on top of the shallow side of the shim. You slide the shim onto the bottom of the brae bracket that is already on the axle. Keep the spirng on the shim (the little tab ears on the spring catch the outside of the shim). Tap the shim/spring in till is sits flush with the bracket on both sides and insert the allan bolt. Done.
  11. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    I remember my first time....
    GAHHHHHH it is tough.... but yes... you take the allen screw out.. bang out the wedge with wavey metal....
    if you think it is interesting trying to get them out.... that is always the easy part... wait till you try to put it back together...:haha:
  12. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,812
    396
    Clayton Del
    If the caliper is loose I think you can get thicker shims . I know you can for a Dodge.
  13. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    Where? auto part store? i just need the stock one. i have a wobbly caliper now cause i lost one.:doah:
  14. BoondocK5
    BoondocK5 1 ton status Author
    May 13, 2006
    10,035
    63
    Salt Lake City, Utah
    usaully I find them on the "help rack" at NAPA
  15. 86Cucvbeater
    May 24, 2005
    428
    north carolina
    lol cool thanks
