how do you get the carpet glue up?
Discussion in 'The Garage' started by jjlaughner, Nov 19, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I need to peel this stuff off so I can do bedliner once the new floors are in.
    Chizzle? Heat it scrape it? File it off? Grinder? Torch /forums/images/graemlins/rotfl.gif
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I used a heat gun and it made it gooey then I was able to scrape it on off of there. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I just pried it off. Came off in big chunks. Was easier when it was warmer though because it was pliable. The crap I waited until fall to get off was harder because it was cold and had no real give to it.
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    thats what I'm running into... its cold outside...
    Next couple days are going to be 59 highs, so maybe I can pry it off then, when I pulled the carpet and insulation out is was in the upper 30's
  5. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    I forgot to say I used a hairdrier and it helper some...
  6. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    if its really cold/hard that could be a good thing... I used a combo of putty knives/screwdrivers/chisels to get most of it off... then I realized I was doing things the slow way and just grabbed my grinder. /forums/images/graemlins/grin.gif
    j
  7. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Unless you have a real good heat gun, use a small propane torch and a putty knife. It works well for the rubber crap under the front floors also.
  8. badassblazer03
    badassblazer03 Registered Member
    Oct 2, 2003
    82
    Amherst, NH 03031
    I used a really course wire brush for my grinder, it worked great. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  9. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    grinder, grinder, grinder. Anything else is a waste of time IMHO. Since you are going w/ bedliner, a little extra "roughness" won't hurt.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  10. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    3M Release agent works the best..it desolves the glue..
    Prep-sol solvent by Dumont or any wax and grease remover will work.. /forums/images/graemlins/thumb.gif
  11. rcurrier44
    rcurrier44 1/2 ton status
    Oct 13, 2003
    320
    You mean the 1/4" thick sound deadening matt? If so get a block of dry ice (or anything very cold - dry ice is cheap). Rub the block of ice across an area to freeze it and then smack it with a hammer. The stuff just shatters and falls off.
    Race car/truck guys do this all the time.
  12. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    OH GOD make it go away...that looks like my blazer /forums/images/graemlins/rotfl.gif neat that ur fixing it though..id like to see how you do ur floor..ive been toying with the idea of fixing the blazer up, meaning do something with the floor to make it a drivable vehichle...the thing is half parted out now..but i still always wish i could do something with it..
  13. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I would try air craft striper(strong paintstriper) works petty good but havent tryed it on glue but it heats up what ever you put it on but dont get it on anything plastic becuase it will melt it /forums/images/graemlins/thumb.gif
  14. romanviii
    romanviii Registered Member
    Oct 31, 2003
    13
    California
    Paint stripper will definitely do it, Just remember to remove every trace of it before applying anything over the treated surface. Blue Lightning is the best stripper I have ever used it removes everything but metal. Its violently good. -OR- I managed to sand off carpet glue residue with a DA sander and 60 grit one time. Barbaric but true....
