How do you get the clutch fan offa the water pump?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PetaKane, Oct 6, 2002.
  1. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    I've never had difficulties with the older style fans, but this serpentine pump is giving me hell. It's an 11 or 12 blade fan can't remember, should I just leave it on there?
  2. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    OK Ill shoot here. I dont remember exactly what it looks like but is there just 1 BIG nut at the water pump? If so you need to remove that. That is what holds the whole deal on. NOW It may or may not be reverse thread. Youll need to hold the water pump pulley and bust loose the big nut. It can be a challenge. A pair of huge Channel Lock Pliers works well for this.
    PM Twizted if he dont show up in this thread. He works at a Chevrolet dealer.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Doesn't it have the 4 nuts on the shaft ???
  4. PetaKane
    Apr 17, 2002
    530
    Oklahoma City OK
    Daggum PI, you always know what you're talkin about! Everytime I've had a question on here about Vortec motors, you remember from when you did yours I guess. Big help man, I saw the nut, bigol thing too. It's bein a pain in the butt gettin it off, and I can't tell if it's reverse thread either. I guess it'll eventually come offa this thing if I keep turnin it. Thanks again
  5. Sandhills Blazer
    Sandhills Blazer Registered Member
    Nov 6, 2001
    45
    South Carolina
    Just remove the four nuts and the fan will fall off in your hands.
  6. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    I just did one a couple days ago and I think it used right hand threads.
    /forums/images/graemlins/truck.gif
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I'll agree with standard right hand threads. Righty-tighty, lefty-loosie. I replaced the water pump on my dad's suburban and jammed something between the engine block and serp belt pulley at the water pump. Then just grabbed on with a BF channel lock pliers and turned.
    Here's a tip on what not to do when replacing the water pump. If you want to make sure the new gaskets line up with the ports and bolt holes, DO NOT put a little dab of RTV sealer on the gasket and plaster it to the block. You will not get it to seal properly. If you want to hold the gasket to the block, put RTV all the way around the gasket. If you do put a little bit on and it doesn't seal properly, you'll have to start back at the beginning. Don't ask me how I know this.
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Another way I did it and it seals perfect it to put a few touches of grease to hold it.
    The grease will slide and make it fit perfectly and it will not make a gap to leak. Personnally I coat it with the grease but all you need is a couple of spots to hold it in place.
    IceMan
  9. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    why not just put the gasket on the water pump with some nice RTV and then put the bolts through and attatch it to the block after some more RTV? just a thought anyway thats what i did and not a leak yet. /forums/images/graemlins/smile.gif
  10. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
