How do you get your floor SMOOTH
Discussion in 'The Garage' started by CaveBlazin, Sep 18, 2002.
  1. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    Ok I got up all the crap and most of the rust off the floor of the cab but its still ruff in various spots and I would like to just strip it down to bare metal and make it smooth and shiny to paint over with the por-15. I've been using one of those paint/rust remover wheels with my drill but it just aint workin that well. Whats some other tools I can use to smooth it down real good. Please help I know yall have done this..
  2. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    Grinder with a sanding disc...80 grit works well.
    Rene
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    or a grinder with a twisted wire brush or wheel will eat through some tough sh!t.
  4. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    And those will take out that rust and paint and smooth it out real nice??
  5. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    You may be better off to cut out the bad stuff and put in some new sheetmetal...the more you grand the thinner it gets...just my .02
  6. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    sander and 80 grit to get all the old finish off then metal ready and por15, it will be smooth when you're done
  7. beater74
    May 29, 2001
    1,749
    atlanta
    if yor floor has serious rust nothing will remove the pitting that is caused by the rust. but a wire brush on a grinder will remove everthing and you will save on the two dozen sheets of sand paper a sander will eat up. a wire brush on a drill will not do half the job a grinder/wire brush will. IMLAO
  8. Skroo
    Skroo 1/2 ton status
    Jul 13, 2002
    137
    Houston, Texas
    3M makes discs called roloc. They come as pads like a sanding disc or discs that go on a drill. These things will eat up paint and rust but will take off very little metal. I use them at work before i weld panels on cars. Since it doesn't take of much metal I have thicker metal to weld on.
  9. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Dude!! You just need to tell your wife to go UA and move that a$$ back to Nashville, come over to the house with much beer and I will HOOK you up!!! 10-4? /forums/images/icons/grin.gif
  10. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Im working on that now!!
  11. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    If you've got pitting and want to keep the most amount of metal possible, I would think sand blasting would be the best way to go, then fill the pits with a thin layer of body filler or fiberglass resin (just enough to smooth the pits). Rouhg that up a little when it cures and coat with your favorite coating.
    I did the same thing with mine, but it was really bad, got major swiss cheese. I had just enough of a metal matrix left to fiberglass over. I know, I should have gone new sheet metal, but the whole body is so bad Im just putting temp structure to keep it streetable while I build the drivetrain, then I will try to find a better body. /forums/images/icons/wink.gif .
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am goign to add one more option for a grinding wheel. GO to Lowes or a local harware store and find grinding discs that have small layers of sandpaper type stuff over lapping each other... THese wheels eat stuff like it is goign out of style!
  13. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    if you are planning on bedlining it it,you shouldnt have to worry about little pits and imperfections.the bedliner should fill that in and be smooth anyway after you lay it out.if you put on a good thick layer it will also be like insulation and keep some of the road noise and engine heat away from your cab.
  14. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Once your floor is rusty & pitted, the Best way would be to sandblast, epoxy prime and paint! It is the only way to get many years of RUST free metal!!
    But if you are going to use POR-15, I'd just put it on heavy, for your last coat. The POR-15 will hide 50# grit grinder marks, so don't be afraid to get aggressive on the metal. Remember POR-15 has NO UV PROTECTION, so you must at least rattle can over it!!! /forums/images/icons/crazy.gif
    Don't forget to get some rubber gloves, it takes weeks to get the stuff off your hands!!! /forums/images/icons/smirk.gif
