How do you measure...........????(Math Dummy needs help)
Discussion in 'The Lounge' started by Can Can, May 6, 2002.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    How do you measure the area of a rectangle that has two equal sides and two different sides? Does that make sense?
    What is the equation?
  2. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    multiply side A with Side B to get Area C...
    if Side A of a rectangle is 4 inches, and Side B of a rectangle is 6 inches, then the area is 24 square inches.
    The confusing part about 2 equal sides, and 2 different sides is the side Paralell to Side A is the same length as Side A and the side Paralell to side B is the same length as Side B.
    Side A
    ________
    I_______I Side B
    Area = C.
    sorry for the bad ASCII drawings, but the boards automaticaly remove spare spaces....
    I hope that helped a little, and didn't make it more confusing...
    -Rich
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    like this?
    A. take the shorter nonsame side (top) and multiply it by the height.
    B. Then then take the short side (top), subtract it from the long side (botto,), multiply it by the height. Then add A & B together.
  4. Can Can
    15,552
    136
    Sorry Rich, but now I'm really confused!!!/forums/images/icons/crazy.gif
    I was actually trying to figure out the dimensions of this rectangle-
    1. Top and bottom are both 300 ft long.
    2. One side is 706 ft long and
    3. The other side is 735 ft long.
    Anybody? C'mon, help dodo-head Paul out.
  5. Can Can
    15,552
    136
    Let me see if I can figure it out, brother!!!/forums/images/icons/smile.gif
  6. Can Can
    15,552
    136
    I got 220,500 square feet......Is that right? Now what do I divide that by to find the acres?
  7. Ddragggon
    Apr 25, 2001
    2,657
    that be a trapezoid...
    the answer Hossbaby gave should work... are the top and bottom paralell? if so, then the questionmay have been written wrong...
    lemme see iffin I can find a math website that'll be able to explain it better, and with good pictures...
    -Rich
  8. The_Sandman_454
    The_Sandman_454 1/2 ton status
    Sep 9, 2001
    209
    Michigan, USA
    Wow that would be a bear to figure out since there's no 90º angles in that thing, and worse yet no parallel sides. Can estimate fairly well... If nobody has the answer by tomorrow I'll try and figure one out...
    It's too late in the night for me to try and do any thinking like that. But standard things to calculate a trapezoid, rectangle, etc can't be used... I think it might involve calculus... /forums/images/icons/crazy.gif
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am getting roughly 215897.82 sq. ft.
  10. Can Can
    15,552
    136
    Like I said, Rich, I'm a total math dropout....... If that's what it's called, then I guess it's a trapezoid(See my measurements above). And I totally agree that the question was asked wrongly - so slap me/forums/images/icons/wink.gif.
  11. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Are the 706 and the 735 lines parallel? My above measurement above is assuming that they are.
  12. MXmastermike
    MXmastermike 1/2 ton status
    Dec 23, 2001
    167
    Columbus, Ohio
    there's 43,560 sq feet in an acre. i dont have a calculator handy, but thats 215897.82 divided by 43,560 for the acreage
  13. Can Can
    15,552
    136
    How did you come to that total, brother???
    Here's my math:
    1. 706 x 300 = 211800
    2. 735 - 706 = 29
    3. 29 x 300 = 8700
    Sooooooo............8700 + 211800 = 220500
    Isn't that right? Or is there the a problem beacuse of the angles?
  14. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    So there is roughly 4.956 acres in the area you asked about if my calculation is correct.
  15. Can Can
    15,552
    136
    Yes the 706 and 735 lines are parallel........And if this makes a difference so are the 300ft sides too. They are in a shape like this:
    _______
    / _____ /
    Thanks for all the replies, guys!!!/forums/images/icons/smile.gif
  16. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    I'm no expert but I don't think all the sides can be prallel. If they are then it's a rectangle right? I hope, for ease of calculation, that the 700+ sides are parallel.
    -Aaron
  17. Can Can
    15,552
    136
    I see what you're saying, Aaron....../forums/images/icons/tongue.gif
    I guess what I meant to say is that the two long sides are parallel and the two shorter sides lean the same way. Does that make sense?
  18. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    300 wouldn't be your height. You have to use the pythagerian therum to figure out the height. the height is actually 299.65. so use the 299.65 as the height and it comes out to rougly my earlier number.
  19. Can Can
    15,552
    136
    The what thereum???? Man oh man, it's been a long time since high school/forums/images/icons/crazy.gif. I think I had a little too much vodka at lunch the day we learned that/forums/images/icons/wink.gif.
    SO you figure the area is just shy of 5 acres? Good......that's what I was told.
  20. MXmastermike
    Dec 23, 2001
    167
    Columbus, Ohio
    i dont think we can get this without knowing the distance between the two parallel long lines
