How do you remove the ign switch?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Sledge, Feb 9, 2002.
  1. Sledge
    Sledge Registered Member
    Feb 24, 2000
    75
    Reno, NV
    Hey guys,
    How do you remove the ignition switch on a '72? I got the bezel turning counter-clockwise, but after a while it seems to just spin w/o doing anything. Do you need to remove the key cylinder first, or something? What's the trick?
    Thanks.
  2. wrath
    wrath 1/2 ton status
    Mar 4, 2001
    182
    Grayling,Michigan
    Is there a small hole next to where the key goes in..insert a safety pin or paper clip into that hole while key is in acc.mode..and the whole tumbler will fall out..bezel unscrews after that by holding the ign.switch and spinning the bezel..good luck
    70K5 350ci.350/205 "PROJECT 40"BOGGERS" It runs and its clean !!
    <a target="_blank" href=http://communities.msn.com/OurMudToys/the70k5blazer.msnw>http://communities.msn.com/OurMudToys/the70k5blazer.msnw</a>
  3. Sledge
    Feb 24, 2000
    75
    Reno, NV
    Thanks for the info Wrath. Poked a paper clip into the hole w/ key in the ACC position...feels like I'm depressing something, but the tumbler's stubborn. I'll just WD40 the crap out of it and see if that helps. I knew there had to be some trick to it! Thanks again.
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Sledge,
    This might help.....ask me how I know....!!!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=firstgen&amp;Number=281651&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=firstgen&amp;Number=281651&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1</a>
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  5. Sledge
    Feb 24, 2000
    75
    Reno, NV
    Thanks Greg, I think I was just missing step 3 -- turn it CCW some more. I'm gonna go try it again.
