How do you remove the steering wheel...
Discussion in 'The Garage' started by beastofablaze, Apr 6, 2005.
  1. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    from an 88 silverado K5? I need to get at the ignition tumbler and the manual says the wheel has to come off...
  2. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    i think you pull up on the horn ,instead of pushing down, and there you find the answer, and some bolts :)
  3. beastofablaze
    Apr 4, 2005
    441
    CA
    flathead screwdriver and just pry it up or do i need a special tool?
  4. hi pinion
    Sep 25, 2003
    5,354
    it should "pop" off i think,by hand,, and then you can get too the bolts that hold the steering wheel on , dont quote me, but, im pretty sure :thumb:
  5. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    If the wheel doesn't come off by hand, don't use a hammer. Find someone with a steering wheel puller. Those things save trouble.
    This is basically how they work- there are two dimples for the outside bolts to sit in, and you tighten the middle bolt- which pulls the wheel loose.
    They come in different shapes. I don't know if they're standard for all brand vehicles, or if you need a certain one.
  6. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    to get to the screw you have to remove, you will also have to remove the lockplate, and for this a lockplate removal tool is required (it can theoretically be done without one, but it is well worth the $12 or whatever for the tool)
    they should have both these tools at ANY auto parts store, or places like Harbor Frieght... but if you have a buddy with them, thats best :)
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    lockplate depresser tool is cheap, get one, keep it around
    you need puller to pull the wheel off
    and again do not use hammer
    good luck
  8. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,927
    343
    Fort McMurray, Alberta
    It is extremely easy to make your own steering wheel puller / lock plate compressor. Just find a peice of flat iron about 3/8 thick, or so. Drill a hole in the center big enough to fit over the top of the column, then get your torch, and blow long holes on either side of the center hole. Grind it smooth, and voila, you have a puller / compressor. To use it, just get a pair of bolts that are long enough to reach the steering wheel's puller holes, then tighten a bolt through the center that pushes against the steering wheel's retaining nut (watch you don't mess up the threads on the column shaft) and the wheel will soon pop off. Then to compress the locking plate, undo the two retaining bolts, then put the plate over the steering shaft and put its retaining nut on overtop, then put your two bolts on with nuts on either side, and tighten the bolts, it will push the plate down, and you can then take the snap ring off with a pair of flat screwdrivers. From there on in, its a pretty easy process :)
