how do you remove this?
Discussion in 'The Garage' started by colbystephens, Apr 3, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    ok - need to do some more reading in the haynes manual, apparently. how do i get my steering shaft out? i took the nut and bolt out of the bell shaped deal at the top of the shaft and then tried to hit it with a rubber mallet. that didn't do a whole lot, so i removed the nuts from where the shaft attaches to the gear box, and attempted to get the whole thing out. that didn't work too well. essentially, all i'm trying to do is get the shaft out of the way so that i can get a rubber grommet-like deal into the steering column so that my truck is steer-able. the rubber grommet piece i'm referring to is circled in read in the second picture of my buddy's truck. any ideas? anyone got a real name for the piece i'm referring to?
  2. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    cant see the pictures cause im not a member, but it sounds like you are describing the rag-joint. is it the piece that connects the steering box to the steering shaft? if so it might be easier to take the steering box off instead of the shaft.
  3. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    that's not my goal - but maybe a necessity? i need to get the shaft disconnected from the steering column.
  4. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    try and embed the image instead of attaching it, then i can see what you are talking about.
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i can't upload to the internet. i'll email it to you tho. my email is colbys (AT) pdx (DOT) edu. drop me an email, and i'll send the pic over.
  6. Masiony
    Sep 2, 2005
    729
    Springfield, OR
  7. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    either remove the bolts at the rag joint or pull the box off the frame for a moment.
    iirc, it's called a steering shaft bushing. did you get both pieces? there's the retaining collar ( plastic piece that is visible from the pic) and then there's the bushing inside. I've only done one of 'em and it was last summer so I'm a bit fuzzy on everything.
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    yeah, i've got all the pieces. so there's no way to do this w/ out pulling the steering box? i was hoping to make this a one man job. :(
  9. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    you didnt circle anything on the pic. is this the problem[​IMG]
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    sorry dude, i sent you the pic of my truck, not my buddy's truck w/ the part circled in red. i'll send you another pic. the part which is circled in red is what is missing from my vehicle. what you circled in green is not the part i'm referring to. if you were to move that circle up about an inch, the green circle would be around the part i'm referring to.
  11. hack500
    Sep 16, 2005
    523
    Templeton, Ma
    pulling the box is a 1-man job. 4 bolts and it's off. it is not that hard. it just sounds more intimidating than it actually is. it's easier than dropping the column.
  12. Masiony
    Sep 2, 2005
    729
    Springfield, OR
    this is not the rag joint. and im of no help.
  13. dyeager535
    26,979
    Just use something to get purchase on the pot joint (one circled in one picture with green) and smack it towards the steering box. You could probably drive a wedge (like a big cold chisel) in between the flange on the steering box and the rag joint, but I would rather put force on the steering box than the steering column. I doubt you'll hurt the pot joint when doing this, but they do loosen up with age and wear.
    Where the steering shaft changes diameter (in the first pic, clearly visible between the pot joint and rag joint) GM used nylon injected to hold those pieces "solid" but still collapse in an accident. You can break the nylon by smacking the shaft together, which will allow it to compress and telescope with less effort.
    Won't hurt anything to do that.
    Other than pulling the box, loosening up the column, or compressing the shaft, I don't think you'll get enough movement to get the alignment pins on the ragjoint to clear, which you've found out already.
  14. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i know that pulling it is pretty easy, but i don't want to pull the whole d@mn thing out, so i was thinking a second person would be necessary to hold it up while i do some work. thanks for all the input guys.
  15. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
  16. detailer03
    detailer03 1/2 ton status
    Sep 23, 2003
    108
    Arizona
    The part you are trying to remove is part of the steering collumn.
    Unbolt the rag joint and disconnect the steering column.
    What is wrong with that part and why are you removing it?
  17. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm not removing it - i don't have it. i need to put one in.
  18. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Call me
