How do you reseat a bead???
Discussion in 'The Garage' started by chevyfumes, Jun 27, 2004.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I managed to catch my tire on fire, but thats about it.... /forums/images/graemlins/dunno.gif /forums/images/graemlins/whistling.gif
  2. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i did my tires today, this is what i did, put the tire on the rim, put a piece of wood under it, sprayed eather all over the tire and a trail leading to it then droped a match, then have someone close by with an aircompressor with the tire chuck in it, then when the eather pops the tire on the person with the air hose fills it up , it worked for me
  3. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    You spray the ether on the tire? I just push the tire down and spray the ether on the wheel (the part inside of the tire) and then the trail across the sidewall to the edge. All of the fire is inside.
    Fumes - what size tire and wheel are you working with?
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    You can also wrap a come along or ratchet strap around tire and pull tight , then fill with good air source ( 12v compressor won't cut it ) /forums/images/graemlins/k5.gif
  5. ugly_blazer
    Apr 12, 2004
    1,214
    Just curious, has this method ever been sucessful for you? I have tried this way several times but always ended up getting out the ether. My beads are usually a few inches away from seating because I like to run wide wheels.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have had good luck doing it that way, but I don't run wide wheels.
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Using ether has many variables involved and in my opinion is a last ditch effort to get the tire back on the rim. Some of the variables are the type of ether (Volatility) some won't actually pop but just fizzle out. Another would be temperature and humidity which has to do with the evaporation rate of the ether. The more quickly the evaporation rate the more likely you will get a nice pop. The liquid just burns but the fumes blow. I've had bad experiences with this method. I lost all the hair on my arms and eyebrows were gone. The only thing that changed in my set of variables was temperature and it went from pfft to KABOOM!!! scared the living jaheebees out of me.
  8. chevyfumes
    Feb 24, 2000
    38,584
    266
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gifI think I'll try the ratchet strap....thanks guys.... /forums/images/graemlins/waytogo.gif
  9. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Take it to Discount tire /forums/images/graemlins/rotfl.gif
  10. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Actually the lowest I have gone is 20 psi, so I have yet to lose a bead, I did see someone use it when they pulled over on freeway in 95' with a flat and bead was broken , thats where I learned that trick . /forums/images/graemlins/k5.gif
  11. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I've always had good luck with ether. Just jack the tire off the ground, spray some inside the tire (2-3 seconds) spray a trail and ignite it with your favorite flame source. /forums/images/graemlins/thumb.gif I actually have never done it any other way except when I worked at a tire store.
