How do you set timing on a TBI vehicle?
Discussion in 'The Garage' started by sled_dog, Dec 16, 2004.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I've asked this before but I need to ask again. How the heck do I set my timing on my 89 Burb?? Pictures would REALLY help. I've looked all over for the plug people say you have to disconnect, the only thing I found is a plug thats on the dist or coil(I forget right now) and isn't plugged into anything. I had a small engine fire tonight that resulted thanks to bad timing(backfire) and a small fuel leak I didn't realize was there.
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I have'nt timed one in a while. As I remember, you have to unplug the brown wire w/ the white stripe. it's located in the cab on the left side of the tranny hump near the fire wall, under the dash(passenger side) unplug it, set the timing, then plug it back in! done!:)
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    thanks don't think anyone ever said the words "in the cab" before. By the way, the text color you used is almost unreadable.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    its not under the dash, least not on any ive seen, its on the drivers side of the firewall, under the brake booster, kinda over the steering column. Its in that general area.
  5. unclematty
    Jan 24, 2003
    3,164
    SLC UT
    It's very readable, if your using the forums "night wheeling" skin, sorry man I thought everybody was using it.:whistle:
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Thats where mine is... er... was - back when it had an engine :D
  7. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    It should be a black weather pack connector under the booster, follow the wires from the fire wall back and you should see a weather single wire weather pack connector their. Unplug and time.:D
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The timing bypass wire for your 89 burb should be on the drivers side of the engine compartment by the brake booster like the others said. It is a brown wire with a black stripe and weather tite commector that sticks out of yhe big wire loom. pull the connector apart and set timing to 0*.
    The IFS trucks have the timing bypass in the cab on the passenger side. Or in the relay/connector pannel on the firewall, passenger side of the engine compartment
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    That would be why I could never find the connector on my 1995 k2500
