How do you split the 203??
Discussion in 'The Garage' started by blazen91, Apr 18, 2003.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    The only thing holding me up is the shift rod going to the rear shift fork. How do I disconnect that? TIA.
  2. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    IIRC to disconnect the rod you have to go through the rear of the t-case.
    I was only keeping the range box for the doubler, so I unbolted them like you did, & broke the shift rod off /forums/images/graemlins/grin.gif. Then removed the broken pieces.
  3. Anteak
    Anteak 1/2 ton status
    Nov 7, 2001
    105
    Hemet, Ca.
    Go over to OffRoad Design. I think TonyP has some drawings in his 203 thread to look at. Sorry, they didn't talk about the shift rod. Hope that helps.
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    If it's just for a doubler, sawzall...
  5. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
    i just removed the roll pin on the shift fork that is in the chain side of the 203.
  6. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    I thought of that too!! I got it apart.
    Next question, the 203 I have has 23 teeth on the input. Will that fit a th400?
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    If this is from a chevy there will only be a choice of 10, 27, or 32 spline. The 32 spline version is what fits the TH400.
  8. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yep, you probably have a TH350 with 27 splines (tough to count all them suckers).
  9. blazen91
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    That's what i was afraid of. I have one my back yard I was going to build the doubler with, but I have a th400 in the truck. O well, I will just tear the t case down in the truck.
    Thank you guys for your help. /forums/images/graemlins/thumb.gif
