How do you tell if your Catalytic Converter is bad.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nate87k5, Aug 3, 2000.
  1. Nate87k5
    Nate87k5 Registered Member
    77
    Phoenix, AZ
    Just wanting to know what the symptoms are for a bad Cat. are. Thanks for any help.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Hesitation, low power, bad gas mileage..........It'll just run like crap overall, kinda' like a stuck choke without the gas smell!
  3. 87 mid canada k5
    87 mid canada k5 1/2 ton status
    Jul 20, 2000
    105
    Winnipeg Manitoba Canada
    I've heard they smell bad and the material inside begins to crumble, you may be able to hear it rattle around if you bang on with your hand. You may want to wait for a more technical answer, I'm sure someone will have one!
    MIDCAN k5
  4. bigdaddy89
    bigdaddy89 1/2 ton status
    May 18, 2000
    422
    Phx, Az
    Nate,
    You are still alive! The cats that were put on our blazers suck. If you have the money, just get it replaced. Get a free flow, it will help with power. Call me in the morning. We buy ours from a company in Mesa. I think they are about $50.00.
  5. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    If it's bad you'll have no power when you jump on it . It will sound like it's screaming but won't move very fast .
  6. Canuck
    Canuck 1/2 ton status
    183
    Forrest, Manitoba, Canada
    When you take it off and it weighs 100 lbs.
    Canuck
    Go Wide or Stay @ Home
  7. CruisinK5
    CruisinK5 1/2 ton status
    Jul 8, 2000
    164
    Georgia
    I am with the other guys loss of power and a funky smell are the ones I have heard of.
    "Have you driven over a ford lately?"
  8. ohio_frotyk5
    ohio_frotyk5 Registered Member
    Aug 2, 2000
    13
    OOOOOOhio
    *cough* Straight pipe with glasspacks!!! :)
  9. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
  10. CruisinK5
    Jul 8, 2000
    164
    Georgia
    I also took mine, well lets just say the cat is no longer with my K5.[​IMG] I gained lot of power too.
  11. Nate87k5
    77
    Phoenix, AZ
    Well, just to update you guys... I went ahead and had a High flow Cat and megaflo muffler with 3" pipes and tip put in yesterday. The tail pipe and muffler has several holes in it and the Cat has 147,000 on it so I figured it was due to be changed. Looks real nice and sounds burly. Notice just alittle bit more low end torque and better acceleration so far. Just got to get use to the low rummble sound of the muffler. Set me back 320.00. The shop that did it were really good and did exactly what I asked them to do(time for the shackle flip). If any one is interested in the shop that did the work here in Phoenix, AZ just send me an e-mail. Thanks for all your input.
  12. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,793
    100
    Paducah, KY
    Anyone ever hear of water coming out of the tailpipe if the cat is bad? My buddy said this, but he isn't exactly a mechanic. I had to explain to him what differentials did. However, every now and then, I do get water coming out. I'm almost convinced it's condensation, but water out the tailpipe in 95 degree SoCal midday heat?
    1992 Blazer Sport, 350 TBI, 4L60, 3" Gibson, K&N, 3" Rancho, 285/75R16 on 16x8 Baja's
  13. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Wow!!! Have we discovered a new way to grow water???
    Somebody tell the government!!!!! We could get rich!!!
    hehe
  14. Cua757
    Cua757 Registered Member
    Jun 4, 2000
    30
    Edmonton, Alberta
    Grow water???? That's pretty good 4X4Blazer.
    Ever Been Dirty Rotten Filthy Stinkin' Stuck?
  15. Grim-Reaper
    7,385
    Atlanta
    It's condinsation. I live in atlanta and plenty hot here and it happens on both my trucks all the time and I don't have cats on either of them. smack your friend around and tell him to quit smoking crack.
    As for cats. little tip. Catco makes some of the best flowing cats. Autozone sells a generic Catco cat thats rated to 5.2 liters for $50 a piece. It is made out of the same material that is in the High flow but its just a smaller cat so not rated up to the 5.7 we need. If you run duals your only running 2.85 liters through it and well under half it's rated capacity. The single high flows usualy go for $150 in the size needed for our trucks.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  16. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
  17. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Is a Sulfer smell at high way speed, a good idea that my CAT has to be changed?
    BIG COX
  18. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    MMMM....yeah...stinky sulfur smell isn't a good thing with converters.....i just hacked all my sh!t off from the y-pipe back and shoved on straight pipe.....lots more pep now....lots more windows rattle as i go by too....still working on that!
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  19. WakeBoard&4X4er
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    Is it hard to cut that off and put a new pipe in that location?
  20. MICHIGAN BLAZER
    296
    not if you have a sawzall. actually my converter/y-pipe connection sat right on top of a crossmember....a little bit to the rear, I just took a grinder and ground the inlet of the cat...only through the cat exhaust pipe...not through to the second (y-pipe end) and hammered and pryed it off. At the time it was easier than using a hack saw. I did it at that point in the pipe because it looked like the only true 3" portion of the pipe. i put on a 3" to 3" adapter and my 10' section of 3" pipe...clamped it up and viola....done. had the tailpipe bent out to the side about a week later...right now in the process of finding something to use as a baffle at the tip.....to take a little bit of the edge off.
    87 Cherokee
    65 IH Scout
