How do you tell the difference
Discussion in 'The Garage' started by Cricket, Sep 25, 2005.
  1. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Is there a visual or figural difference between 10 bolt and 12 bolt 30 spline inner axle shafts?
    What about stubs?
    I'm trying to determine just what axle sets I have aquired. :confused:
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    No such thing as a 12b front.........
  3. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Well hell, Dana 44 is what I meant. The difference between 30 spline D44 and 10 bolt axle shafts.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Count the splines, I dont think D44's are 30 spline.
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Ooops, there you go thinking again.. :p:
    D44's do have 30 splines, as far as I can recall anyway.
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Later model 10b's are 30 spline as well.
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    The shaft length should be different. The neckdown on the axleshaft is probably a little different too. The best way I know of though is the length of the shaft.
    Harley
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Dont know that much about these little axles :p:
    but I DOOO know the stubs and joints are the same :D
  9. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    The other way to tell? See if it fits...
    Not too hard, I can have the thing down to the stubs in 15 minutes.
  10. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    You may try checking the diameter. I think the 10 shaft is about 1.28 .. and the d44 is over 1.3 .. maybe 1.31 or 1.32 something like that anyway. I know it's not a lot of difference, but may help. :dunno:
  11. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Pleeeeeezzzz
    The 10 bolt, would be what you just pulled out from under your K5.
    Wheres the :kickballs: when you need it! :wink1:
    :D
  12. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    That's for 28 spline---1.28". 30 spline 10 bolt and Dana 44 shafts are both 1.31". Only difference is spline cut, really.
  13. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    COO :thumb: I was wondering about that.. wasn't sure what the 30 spline 10b diameter was. I'm lucky to remember the diameter as it is.. :rolleyes: :doah:
  14. Cricket
    Nov 29, 2004
    8,224
    Colorado
    From what I can find the length for the truck axles before 1988 is 31 5/16, only problem the D44 is the same length.
    Here's a few pictures, see what you think.
  15. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    The seal neck down on the long inner looks to be a 10b shaft.
  16. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I made this picture years ago and sent it to both Randy's R&P and Stephen at ORD when the big 30-spline 10-bolt debate started:
    This is a Dana 44 shortside inner laying next to a 30-spline 10-bolt shortside inner.
    As you can see the length is different as the offset of the differential is slightly different between the D44 and 10-bolt. On the longside shafts the D44 is longer than the 10-bolt. Also the seal surface area is completely off between the two types.
  17. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Eureka! Hey 6.2 would you happen to have the measurements for the short/long D44. At least I'd have the high and low figure.
    The D44 shaft looks like it has less of a neckdown and a more pronounced shaft seal base. I think I've got the D44 shafts.
    By the way THANKS!
  18. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    10-bolt:
    Short Length 19.15 in.
    Long Length 35.46 in.
    DANA 44
    Short Length 18.31 in.
    Long Length 36.13 in.
  19. Cricket
    Nov 29, 2004
    8,224
    Colorado
    :bow: Genius - Sheer Unadulterated Genius :bow:
    Thank you!
