How do you tell the difference ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SWAMPRNR, Feb 7, 2002.
  1. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    How do you tell a dana 60 from a 70 ? I tried the axle chart but it wasnt much help.
    <font color=red>A BIG HAMMER CAN FIX ANYTHING.... </font color=red>[​IMG]
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    one is Big and the other one is REALLY BIG , our motor home has d 70 ill see if i can get pics or measurements or sumthing
    pics page
    <a target="_blank" href=http://www.imagestation.com/album/pictures.html?id=4292257869&show_all=1&start=1>http://www.imagestation.com/album/pictures.html?id=4292257869&show_all=1&start=1</a>
    always gets me home K10 STEPSIDE
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I believe on the center section if you are looking at it from the rear... at the cover... on the right hand lower side there should be a number casted into the center section of the housing...(or in the middle top of the center section above the pinion) either a 60 or 70 and maybe along with a couple other numbers or something...? thats my best guess as far as i can recall... Anyone else?
    The D60 has a 9.5" ring gear
    The D70 has a 10.54" ring gear so it should be quite bigger.
    [Real Men Don't Care About Gas Mileage Or Rapid Tire Wear!]
    1972 K/5
    Ryan B.
  4. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    There will be a 60 or 70 cast into the webbing of the center section. I think it's on the front of the lower right webbing. (if you're looking at the axle as it is installed in the truck). Alot of them have the number cast on top of the pinion but not all, the webbing number is always there.
    80 K10 w/ 468 and 1 ton stuff
    You don't scare me, I got chunks of guy's like you in my stool!
    www.nvrenuf.fws1.com
  5. SWAMPRNR
    Apr 7, 2001
    296
    Temple Texas
    Thanks... I found the casting number. looks like it going to be a dana 60.
