How do you test the Front axle U-Joints
Discussion in 'The Garage' started by Cmoe, Jun 3, 2005.
  1. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    How do you know if they are going out?
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    best method is to pull the axle out of the differential
    then rotate the stub through all angles, if you feel any resistance or grinding, replace them
    without pulling them from the axle housing, its really hard to tell for sure, but when in doubt, replace them
  3. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    take frt shaft from case and twist it by hand and watch for play. or look for rust from caps. and last like above listed. and in my opinon only use the best spicer or brute force joints in the frt axle area.
  4. dyeager535
    26,979
    Asked a similar question a couple of weeks back, didn't really get much of an answer.
    I was looking at mine under the truck, and noticed that there was a "crack" in the material over the u-joint cap (uses a small pressed in metal cap I guess) and the axleshaft, which is apparently paint, because it's hard.
    I suspect this is an indication that they are going bad. The one axleshaft I've seen before that had a bad joint in it was also missing this, like the u-joint caps start to walk out of the axleshaft or something. Just looked it up in the parts manual, they don't break it down any further than "u-joint repair kit".
  5. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Thanks guys I guess since it's going to be pulled apart anyway I might as well rebuild it..... 27 years old I guess it's time..... Anyone have a set 4:10 gears they want to sell (for a Dana 44)?
  6. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    I just pulled mine to replace the ball joints and I found both sides are bad. They only move on one plane by hand, I can't believe something didn't break last weekend!
  7. mechted
    Oct 19, 2003
    765
    Granbury, TX
    thats exactly how i discovered mine were bad... replacing the ball joints
    PO didnt know what "grease," "maintenance," or "safety check" mean
  8. sweetk30
    Nov 1, 2004
    25,539
    538
    sounds like its time. and what gears do you have now? the carrier split is 4.10-up. you might need a carrier. if so pm me i have one.:D
