How does GM regulate fuel pressure?
Discussion in 'The Garage' started by Pookster, Sep 11, 2004.
  1. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    How do the 87 and up GM trucks with the in tank fuel pump regulate fuel pressure? Is it internal to the fuel pump? or is it a pressure switch somewhere else?
    Also, what are these pumps designed to handle? (Im curious as to their max pressure).
  2. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    The fuel pressure regulator is in the throttle body. If you look it is towards the back upside down between the injectors.Fuel pressure should be in the 15 lbs area. It isnt adjustable unless you purchase a adjustble one or If buy a vacuum refrenced one from gm.
  3. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Im using it for another application, which is why im asking- im concerned that the pump will put too much pressure, or not know how to shut off at the right time. I guess that is the case-
  4. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    You know I still havent installed those headers yet! /forums/images/graemlins/rotfl.gif
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    The pump does not shut off when the engine is running. That is why TBI have a fuel return line. Also the regulator will not function without a return line. I think the stock regulator will handle around 35 psi. It may rupture the diaphram at higher pressures causing a major fuel leak all over the engine. Dont use a high pressure fuel pump.
  6. Pookster
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I want to use it to pump diesel "like" fuel- In my case, it will be vegetable oil. I dont see any particular "issues"with the whole setup, except that the stock lift pump is only supposed to generate about 4-7psi, and I will be using a stock fuel pump that could be moving quite a bit more PSI's. Just wondering if there is any issues in doing so. There's nothing to regular fuel pressure in my setup, so whatever that pump can pump, will be shoved toward the lift pump.
  7. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,089
    489
    Grand Rapids area
    The guys over at www.greasel.com/ give lots of suggestions for pumping the veggie. Running SVO is some intersting stuff!
  8. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    OH!!!
    And you were worried about ME making oil slicks!!!
    /forums/images/graemlins/shame.gif
    Good luck friend!
    /forums/images/graemlins/woot.gif
