How does the fiberglass top of a K5 hold up in a roll?
Discussion in 'The Garage' started by guido666, Nov 25, 2005.
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    Just wondering how well the fiberglass top on the rear of a non-full-convertable K5 holds up in a roll. I didn't know if it was reinforced or if it would just crush.
  2. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    from what i have heard, in a rollover the fiberglass tops tend to stay in one piece, the only downer is, that they ushally seperate from the rest of the vehicle. this really makes the rear seatbelts dangerous if they are strapped to the top
  3. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Yeah. So do the bolts shear off or do they just rip the caged nuts out of the bed rails?
  4. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    They don't hold up well at all, here is a picture of my friends truck. The top didn't stay on or stay in 1 piece.
  5. guido666
    Feb 16, 2005
    788
    Longmont, CO
    It looks like it just ripped off the bolted down portions.
  6. white-rhyno
    Jan 27, 2002
    942
    It was cracked all over the place... was basically in 3 pieces when set back on the rig to drive home.
  7. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    They are crispy and crunchy. I made mine stronger with an interior layer of paper machea and an external layer of spray paint. This made it much stronger. And quieter. I'm not even scared of rolling..... Seriously, they don't do much from what i've seen. Somebody show that roll with the two guys on potato salad hill. Watch what happens to that blazer and then realize how lucky those guys are to have their skulls intact.
  8. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
  9. guido666
    Feb 16, 2005
    788
    Longmont, CO
    It would make sense that it could hold if it rolled on something that spread the force out, like sand or soil. However, if it hits a rock or something that creates a pressure point, it will surely crack and then it's a sure thrashing.
  10. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    guess it depends on how many times you roll. I rolled my 78 3 1/2 time down a hill at TDS this year and it held up fine. and only one of the glass side broke out the other stayed in tact.
    pretty much the only damage was right here
  11. koldsimer
    Jan 10, 2005
    1,480
    texas
    Wow! I can't believe that it didn't do more damage to the top. It looks like the front of the truck took the majority of the roll but I still can't believe it didn't smash it to bits. Makes me feel a little bit better about not have a cage.
  12. onlychevy6
    Mar 29, 2003
    1,293
    Hockley, Texas
    yeah mine did not have a cage either. It was all factory. The main hoop even held up just fine.
  13. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Yes, but it was discovered that those guys driving that truck did not have all of the bolts bolted down. With all of the bolts in, a flexy truck runs that chance of cracking the top at full flex (due to frame flex). I think it was discovered that the truck that rolled on potato salad hill only had 4 of the bolts in. :eek1:
    BTW- The fiberglass tops are reinforced with steel at the points that take the brunt of the impact in a roll. There are a ton of factors that will determine if the stock hardtop holds up to a roll. If it is a slow roll, then it should hold up pretty well. If it is a violent, multiple roll, then it might not be pretty. Hell, many interior cages need to be re-done after hard rolls.
    -Harrison
  14. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    :screwy: Note to self.... Yellow K5's roll more often.... DO NOT paint K5 yellow
  15. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    mine flattened right out and just expoded. mind that was after doing an endo at 100 kph. the cab held out ok tho but if there had been anybody in the back it wouldn't have been pleasant.
