How does the transmission come out?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sample, Mar 23, 2003.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    I am attempting to remove the POS 700R4 transmission from the K5. I have removed froa=nt and rear driveshafts, transfercase, crossmember. I have unhooked all wiring and linkages, removed the 6 bolts holding the bellhousing onto the engine, I have removed the support arms from the 700.
    I can get the tranny to move back from the engine about a finger's width, but no further. Is there something I am forgetting to remove?
  2. RATAH
    RATAH 1/2 ton status
    Aug 10, 2002
    576
    Franklin,Ohio
    The 3 flywheel bolts
  3. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    The 3 flywheel bolts /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. Sample
    Oct 15, 2002
    536
    Apache Junction, AZ
    Don't you guys mean the 3 FLEX PLATE bolts?
  5. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    RATAH did......I just pasted his reply because I agree and I am too lazy to type. /forums/images/graemlins/pimp1.gif
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Also, don't forget to remove the filler tube. /forums/images/graemlins/shocked.gif It's usually bolted to the back of the passenger side cylinder head, in such a way that you need to be a contortionist to remove it. /forums/images/graemlins/eek.gif
  7. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    No freegin kidding. I ended up removing my whole exhaust manifold just to make it easier (was coming out anyway, just not that day).
  8. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I was lucky when I removed my tranny this summer. The fill tube wasn't connected. I did forget to reinstall it before the tranny was totally bolted in though. It wouldn't fit back in there because of the bracket for the bolt. So I just took the angle grinder and cut the bracket off the tube and weiseled it down in there. It has been fine without anything holding it now for 8 months.
