how does this work? 2" traction bar lift on ebay...
Discussion in 'The Garage' started by broncoman6524, Apr 17, 2007.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
  2. SUPERSUB87
    SUPERSUB87 1/2 ton status
    Oct 16, 2006
    463
    TEXAS
    beats the hell out of me. those don't even look like traction bars to me.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    has to wrap before it starts to work. Good luck flexy with it...
    standard anti-wrap bars are a much better idea.
  4. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    im not thinkin about buyin them i just wanna know...where would they get installed? the frame and axle and when the axle twists rather that twisting down it pushes down on the ground?
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i believe you put the top part through the leaf springs (similar to a clamp), and the bottom part is like a 2" block (between the leaf springs and axle perch), thats how you get the 2" lift. make sense? it would help with wrap, but the traditional trac bars would be much better
  6. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Would mount between the spring perch and spring (2" lift part) then the springs go between the two pins. they are adjustable for the number of springs in the pack and the amount of wrap or load you want prior to the bar loading, causing it to press downward on the axle giving more traction
    I guess MuddyBuddy beat me to it. Yeah, what he said.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    they are blocks. often called "traction lifts". They install between the springs and axle. When the axle wraps, the added parts catch on the springs and prevent them from wrapping any further.
    When an axle wraps, it basically spins around its center(axleshafts), and distorts leaf springs in sort of a ~ shape. Thats what the traction lifts count on.
    However, they have to start wrapping to prevent wrapping...
  8. mello_yello
    mello_yello 1/2 ton status
    Jan 16, 2006
    167
    Orange, CA
    they would mount similar to this...
    (crap i cant get an image to work, well basically what everyone else said, sry)
