How easy/difficult is it to swap rear 10 bolt for 3/4 14 bolt?
Discussion in 'The Garage' started by la_blazer82, Aug 10, 2004.
  1. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    I'm holding off on lifting the K5, as I have decided on going with a 3/4 ton 14 bolt open rear. Is this something that I can do on my own (regular driveway mechanic w/no welding skills), or should I get a shop to install? What's an average price for install (in SoCal)?
    What TC springs should I get (currently 1/2 10 bolts F/R) if I want to go for 6" of lift? 4" f/shakle flip rear, 1" ORD zero rate and 1" ORD body; or 6" front/2" rear w/shakle flip? Do I have to drop down the T-case with the 4" lift.
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    pretty shure 14 is bolt in for the 3/4 ton axels, but you will need a conversion u-joint that will eaither need to be pressed in or beat in with a hammer /forums/images/graemlins/waytogo.gif
  3. imaginepro
    imaginepro Registered Member
    Jun 8, 2004
    28
    St. George, Utah
    I just did mine. It is really easy to do everthing just bolts right up. the only thing you will have to mess with is you will need a I belive it is a 1350 u joint. you should have with your ten bolt a 1310 you can get whats called a converstion joint it matches a 1310 for your drive line and a 1350 for the axle. I just got a new drive line the converstion joint is easy enough to find but I didn't want to break it on the trail and have to order one. any way the only other thing is that you will need slightley bigger u bolts. But I just bent mine I had and they worked just fine. The biggest thing you are going to have to deal with at least I did was your ebreak set up it tooks real minor fab but it works. and you will love it after you do it. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  4. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    DO NOT pay some one to swap your axle. It is really that simple. Look here for a step by step instruction that Steve did. Make sure the 14ff you get comes from a truck and not a van other wise you will have problems. You might also run into a problem with hooking up the ebrakes. If you do let us know and there will be someone to help walk you through it. /forums/images/graemlins/waytogo.gif
  5. la_blazer82
    Apr 12, 2004
    148
    SoCal
    Looks like I may try to do it myself. The 14 bolt is coming off an 83 truck. BTW -- thanks for the replies
    Also, should do I go 3/4 springs f/r even though I have a 1/2 ton up front? And should I go with a 4" TC front/ORD shakle flip, and ORD 1" zero rates; or just go 6" TC front/shakle flip + 2" springs rear? Need to fit 16x10" wheels; fender trimming will probably be needed either way
  6. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Yes, you might have to. It will help alleviate vibrations. You could also by shims that go under your springs that point the pinion up towards the t-case. If you order through ORD they should help you get the right setup.
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I have 1/2 ton springs with 3/4 ton axles /forums/images/graemlins/waytogo.gif
  8. la_blazer82
    Apr 12, 2004
    148
    SoCal
    I notice that a lot of guys are running 4" TC/ORD shakle flips and 35-36" tires. Is this with fender /forums/images/graemlins/hack.gif alone; or is a 1" ORD zero rate or body lift needed?
  9. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Easy is the word of the day. /forums/images/graemlins/thumb.gif It is about as simple as an axle swap can get. It is about as hard to swap in a 14BFF as it would to swap in another 10B. A 3/4 14 swaps directly in and if it is around the same year as the truck the E brake will even work.
  10. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Oh, I almost forgot. The conversion ujoint you will need is Neapco part # 2-1153. /forums/images/graemlins/thumb.gif
  11. la_blazer82
    Apr 12, 2004
    148
    SoCal
    "The conversion ujoint you will need is Neapco part # 2-1153."
    Where could I purchase the Neapco U-joint conversion part?
  12. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
  13. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Napa auto parts
  14. la_blazer82
    Apr 12, 2004
    148
    SoCal
    Quick question: What's better, a 14 bolt rear/open/3.73 (newer) gears, or 14 bolt rear/gov-lock/4.10 gears? Only a $50 difference between the two (the gov-lock is cheaper).
    I'm actually considering 4.10s for my 35"s.
    I just bought new 6 lug wheels for the 10 bolts -- should I return and get 8 lug wheels and use adapter on the front 10 bolt; or keep and adapt rear to 6 lug?
    I know, I have plenty of issues! /forums/images/graemlins/rotfl.gif
  15. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    convert the front to 8 lug.
  16. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    What kind of wheelin do you do? If you can afford to change gears and add a Detroit to the open rear then get the open rear. If not the Gov loc would be a good choice for a begginer wheeler. You will have to match your front gears to the rear 4.10's. I recommend you return the 6 lug wheels and get 8 lug 16" rims. Changing the front to 8 lugs is not that difficult but you do have to find a matching axle from a junkyard that will be will to let you strip the axle from the backing plate out. I don't know if they will let you since the axle would be useless to sell after that for them. I swapped whole axles front and rear. A dana 44 with 8 lug up front is easy to find and will bolt in easier than the rear due to same u joints and brake calipers.
  17. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    George fill out your profile /forums/images/graemlins/waytogo.gif People are not as likely to respond to someone who doesn't give much info on there rig or about themselves here. Also if you get a membership you have more forums to post up in and get more responses.
  18. la_blazer82
    Apr 12, 2004
    148
    SoCal
    Thanks -- just updated my profile /forums/images/graemlins/thumb.gif
  19. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    [/ QUOTE ] Got mine from a machine shop.
