How easy is it to rebuild a rear diff (from a novice perspective)
Discussion in 'The Garage' started by sarasotausmc, Jul 5, 2004.
  1. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    I've searched, and there are answers to most of the questions I have regarding this, but...For a man with limited mechanical skills, how hard is rebuilding a rear end? Chiltons makes it look like a walk in the park, but I don't believe it. Is that something that I can afford to learn as I go using Chilton's , or is there more involved than what they show and pay to have it done?
    Reason for the rebuild question: When driving, I have a clanging noise, almost like a bell sound that comes up after releasing the accelerator or coasting. Tapping on the drive shaft with a hammer makes a similar noise, and with tranny in N with wheels off ground, I can feel "something" grinding/binding when turning wheels by hand.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It is easy to get the parts in, its difficult to set the gears up. You need a dial indicator and a few other items. Some diffs , like c-clip GM axles, require the carrier come in and out several times before you get it right. Many pros who do it regularly have the experience to get it close the first time . I have rebuilt engines, and still do not want to set gears up myself /forums/images/graemlins/k5.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    In all honesty, it may be cheaper and easier too just swap a different axle in. Just make sure the gears ratio is the same.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    If you think its in the rear end, id pull the cover and see what exactly is the matter.
