How far can I clock.... UPDATE!!!!
Discussion in 'The Garage' started by hidesertwheelin, Feb 23, 2007.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I bought a used clocking ring mmade by DPI. I was wondering on a 1990 Suburban, with NO bodylift, How far can I clock my NP241 without having body clearance problems. I think I can go to the second hole, but want to make sure. Thanks.
  2. hidesertwheelin
    Nov 13, 2004
    782
    4
    Hesperia, CA
    Anyone???? I did a search and could not find an answer. I am installing this weekend!
  3. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I've asked the same question.. and I've been told it that theres more room under there than a blazer... so to clock it flat u would have the beat the hell out of the floor...unlike a blazer u would have to cut a hole in the floor. but I'm guessing the 2nd hole would clear.... take pics when u do yours if u go to the 2nd hole so I can see how much the case hangs below the frame rails... desertrat has his case flat on his burb and he beat the **** out of the floor....
  4. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    How much difference would a 1" lift and new mounts make? The obvious answer is 1 1/2", but i am wondering just how much floor beating clearance you need.
  5. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Hmm I've been searching and trying to figure out exactly what I need to clock the 241 on my '89 blazer, I know a clocking ring, and I have a 3in. body lift so I'm not worried about clearance, the only thing I'm worried about are the DS angles... the front I can probably build a square one on my own but if I tilt my TC back up won't that mess with my rear as well? Can I just have it lengthened? Or should I just leave it tilted back for now? :confused:
  6. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I clocked mine up to the second hole on my sub(90, no BL) and had to "massage" the floorpan a bit. I beat an area about 4"X6" and test fit it several times to get it right. I think you can do the first hole without massaging. The floor pan actually creased at one point and I had to heat it up with a torch to get it to bend some more.
  7. cbbr
    Jul 17, 2004
    14,681
    Sounds like my 1" lift would take care of that. Any driveshaft problems?
  8. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I have a 4" lift and clocking it up put an excessive amount of angle on the front shaft. I ground it out as much as possible, but it looks like it is near maxed out at ride hieght. I am looking at going with either a non CV 1350 or 1410 shaft to replace the CV.
  9. cbbr
    Jul 17, 2004
    14,681
    I was afraid of that. I have about 6" of lift, so I would have problems too. Was the DS length ok?
  10. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    I still have the stocker, but put the slip part of my original rear shaft on it to lengthen it about an inch. I think another inch would be better.
  11. cbbr
    Jul 17, 2004
    14,681
    Sounds like I will need to call HAD when I start this project. Thanks.
  12. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    clock it as much as your driveshafts will allow. Sheetmetal is entirely massagable / expendable, don't even worry about that crap. The real question is, at full droop will your shafts joints bind up or not.
    j
  13. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    my shaft= yup, you guessed it. binding
  14. cbbr
    Jul 17, 2004
    14,681
    With 6" of lift, I'm guessing that mine will too.
  15. hidesertwheelin
    Nov 13, 2004
    782
    4
    Hesperia, CA
    Well It fit clocked up to the 3rd (highes clock avail), but I cheated and lowered the t-case 1". I'll post pictures tomorrow. Thanks for the help everyone.
  16. cbbr
    Jul 17, 2004
    14,681
    How does the drive shaft look?
  17. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    That will help with the body clearnce, but will make the angle on the front shaft steeper. let us know how it turns out.
  18. cbbr
    Jul 17, 2004
    14,681
    Top.
  19. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
  20. hidesertwheelin
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I havent installed it yet. I have to sleve it to make it longer. I'll let you know how it fit then, but will probley be in a few weeks, casue I'm going out of town this weekend.
