How far can I move my front axle without moving the steering box?
Discussion in 'The Garage' started by stallion85, Jan 18, 2007.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    How far can I move my front axle without moving the steering box? I was thinking instead of shortening my driveline why not just move the axle forward another 1"? It is already 2" forward from the 52" swap. I was thinking of redrilling the spring perches to move it forward. What's the consensus?
  2. KevinsK5
    KevinsK5 1/2 ton status Premium Member
    Jan 17, 2005
    257
    13
    Golden, CO
    I'd like to know the same thing, assuming the steering setup is crossover.....If it even matters.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
  4. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Well im planning on doing 52's in the front with zero rates moving the axle another 1.5". But Im also going to try and do reverse mount tie-rod.
    Hey anyone know if you could redrill the spring perch and use the offset zero rate? Just thinking out loud.
  5. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    I have crossover so that problem is cure and I also have plenty of front sriveshaft just need to figure it out. I would imagine as long as the drag link is still running close to parralel with the arm it should be ok. Also your pinion angle will come into play, but with only 4" of lift it really is not that bad right now.
  6. moneypit
    moneypit 1/2 ton status
    Sep 3, 2000
    1,382
    COLORADO
    If you have highsteer and minimal lift you have a problem. I had to move my gearbox forward and the tierod/draglink still gets very close under drivers compression. Full Hydro would have been easier!
  7. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Does anyone on here have reverse highsteer? cause im thinking that by going that route would eliminate the tierod/draglink problem. And if you move the axle far enough your shouldnt have to worry about the tierod hitting the oil pan.
  8. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Yah sell your high steer and buy the wfo arms that put the tie rod behind the axle. If I were to do it again thats what I would do
  9. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    I'm interested in moving the front axle forward a lot too.
  10. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    Mine is about 5 inches forward one of the reasons I moved mine is because my draglink hit my tie rod when the drivers side compressed, therefore causing the frame to be in bad shape by the time I got to moving it. My frame will never ever crack there again but I think I may still go to the wfo arms to protect my ram when i go hydro assist. As an aside I never had a problem when I had my 3/4 ton stuff and was just crossover, when I got my 60 I went high steer and the problems ensued
  11. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Got pics anyone? zuk, where is you DL, etc in relation to your axle now?
  12. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    x2. im wanting to go reverse hi-steer, and with the big 6.2 oilpan, i need to get the axle more than just 2" forward (check stallion's ultimate m1008 thread for evidence)
  13. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    5" forward would def let me utilitze the reverse high steer arms I have from WFO. I would have to see how zuks draglink looks going to the steering arm.
  14. muddermilitia
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Man howd you get your axle 5 inches forward? You still have leaf springs?
  15. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    Yeah, how? I'm needing to fit 46" tires under 5" of lift. Gottta keep 'em out of the firewall.
  16. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    BUMP!!!!! SLAM!!!! BANG!!!!!! CRASH!!!!! KABOOM!!!!
    Back to the top.
    The idea is to move the axle so far fwd that you hook the Draglink to the rear of the axle with the WFO arms?
    Enlightened ones, please share your knowledge (PICS:D) with those of us in the darkness.
  17. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    the front of the Willys was about 5" forward I had 57" fords up front. I had sky drill an extra hole in the steering arms and I ran the tie rod in front of the drag link as they would have crossed in standard histeer configuration.
  18. DavidB
    Oct 8, 2001
    2,617
    El Centro, CA
    It's too late, and the K5 isn't here. I can't visualize...
  19. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    mines 3.5" forward with nwf reverse hi-steer arms
  20. Joshinator
    Joshinator Registered Member
    Jan 19, 2005
    58
    Sulphur Louisiana
    I had my front axle moved a total of 6 inches forward with leafs, springs re-drilled 4.5" and a zero rate in the 1.5" hole. I had a 90 degree approach angle with 44's. I ended up taking the zero rate out because i messed up on measuring on the driveshaft and it was an 1.5" too short. I'm running ORD cross over with what ever lift the 52's give me. I turned the offset in the Drag link forward so it would clear the cross memeber. No issues yet, but i do have the suspension limited on up travel to keep the steering arm out of the leaf springs.
