How far can I rotate my 14 bolt?
Discussion in 'The Garage' started by divorced, Feb 3, 2005.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    How far can I rotate the pinion up on a 14 bolt FF before pinion (bearing?) lubrication becomes a problem? It will be on a daily driver so reliability is a factor. The angle in the drawing is what I'm after.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    The 14 bolt is designed so the ring gear slings oil into a hole that routes right through the pinion bearings on the way back down to the bottom of the housing. So long as you don't point it straight up, you should be fine. The fill hole is also in the nose of the housing, so the more you rotate it up the more you can get into it, although it would be more likely to leak out of the axle tubes...
  3. divorced
    Jul 20, 2004
    5,115
    Thanks Shaggy!
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I'd use a high-quality synthetic 80-90W oil if it's gonna be a DD.
