how far off is my speedo
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JMZ, Jun 2, 2002.
  1. JMZ
    JMZ Registered Member
    Dec 4, 2001
    73
    Gonzales , Texas
    I have 3.73 gears and 35 tires. I don`t know what the factory tire size was far these blazers.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I can't tell you how far off your speedo is but I can tell you that it works on a percentage basis and will not be the same at different speeds. I had mine calibrated at a speedo shop for about $100.00. I went from 4.10's to 4.56's with 35's and mine was off by 6%
  3. JMZ
    Dec 4, 2001
    73
    Gonzales , Texas
    Yeah , I know its a %, I figured if it came with 31`s and I put 35`s It is 13% off, but I don`t know what they came stock with.
  4. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,261
    73
    Humboldt/Pacifica, CA
    The easiest way is to have a friend drive in front of you on the highway. When they hit 60 have them tap the brakes and hold the speed steady. Check what your speedo reads and then you'll know the percentage you're off by. I just did this and found that mine is off by 30% /forums/images/icons/shocked.gif
  5. swede413
    swede413 Registered Member
    Jul 7, 2001
    34
    Las Vegas
    head to wallmart and get a G.P.S. set it on your dash and drive around. it takes all the guess work out. If by the end of the day you dont think its the coolest gismo youve got in your truck you can allways take it back and get your money back.
  6. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    mines got 3.73 and 35's.i got pulled over going 60 in a 50 so i guess that mines off by 10 miles an hour since i was going 50.yours is probably pretty close
  7. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Don't work off of the speedo. Set the speedometer gears up to make the odometer read correctly by driving a known length of road and checking against the odometer. Alter the gears in the transfer case accordingly (or get a ratio adapter to over/under-frive the speedo cable the right amount). Then calibrate the speedometer itself correctly (there should be an adjustment for the tensioning spring in the speedometer head).
  8. JMZ
    Dec 4, 2001
    73
    Gonzales , Texas
    Thanks for all the replies.
  9. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    Steve, if the same gear drives the odometer and the speedo, if one is calibrated wouldn't the other be also. I never heard of doing one then the other....or an adjustment on the "spring". /forums/images/icons/confused.gif
  10. Steve_Chin
    Mar 6, 2001
    1,126
    In theory, if you get the odometer calibrated, the speedo should be close. The speedos are never perfectly on, though. I calibrated the speedo in my Trans Am to be dead-nuts on at 120. It reads a little high under 70.
  11. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    So...where did you do this calibrating at 120 /forums/images/icons/shocked.gif ?
  12. Steve_Chin
    Mar 6, 2001
    1,126
    On a dyno.
