How far should slip yoke be in?
Discussion in 'The Garage' started by K5Steve, Sep 24, 2005.
  1. K5Steve
    K5Steve 1/2 ton status
    Aug 10, 2005
    288
    Carson city, nv.
    How far should my slip yoke be in the t case on a 700r4/208?Right now it's in about 2 1/2 inches.A guy I know has the same truck and hi is in about 4 1/2 -5 inches.
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    enought to when you flex the yoke doesn't pull out :)
    sorry I'm no help
  3. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    You can kinda see it in the pic but there is quite a bit of the slip out of the t case.It's a 2 1/2 or 4 inch lift and when it's in neutral I can move the d shaft up and down and the slip moves up and down on the output shaft.
  4. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    that looks like to much hanging out :eek1:
  5. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    i believe the slip is only about 5" long...i have mine about 1-1 1/2" out at ride height...if my rear end is hanging it goes to about 3" of visable slip...so i think it is pretty safe where it is...i wouldnt reccomend the slip be more than 2" visable...it will lead to worn out seals, bad vibes, and it could round out the teeth in the slip...
  6. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    Well I have 3 or more inches sticking out with the truck just sitting on flat ground.I think if I flexed,it would probably fall out.Plus if I unbolt the d shaft and slide it in more,I can't wiggle the slip yoke anymore.
  7. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    When we take our measurements to build drivelines at work, we slide the slip yoke in all the way, pull it out 3/4" and measure center cap to center cap.
  8. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    It's 29 1/2 inches from center cap to center cap right now.I am taking it to the shop to be lngthened to 31 1/4 today.
  9. Pow06er
    Pow06er 1/2 ton status
    Apr 9, 2005
    188
    ne, ohio
    I believe mine needs lengthend and its causing a lot of vibes and it will prolly fall out when wheeled.
    I have aobut 3.25" showing would that be enough to cause play?
  10. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    I could wiggle mine at the slip yoke while in neutral.After lengthening it,I couldn't so I know it was causing some vibes.Look at my pic at top,is it out that far?
  11. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    This is what I found after taking the diff cover off
  12. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    ouch... mine has the slightest amount of play but it could be enuff to cause the shimmy/vibe
  13. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    well thats what you get with gov bombs
  14. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I remember my stock shaft on stock heigth blazer had quite a bit of the yoke hangin out ,similar to the picture 2-3 inches.
  15. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    what does center cap to center cap mean?
    couldnt i push mine all the way in then pull out till 3/4" is exposed on the yoke and then measure in between the pinion and end of driveshaft ujoints?
  16. Pow06er
    Apr 9, 2005
    188
    ne, ohio
    ttt i just would like to know how much slip is exposed on a stock k5?
    and if my method will be ok for finding the amount
  17. K5Steve
    Aug 10, 2005
    288
    Carson city, nv.
    Center caps is where the u joint caps goes in.You should have about 1 1/2" of slip yoke visible.
