How far to disassemble axle before welding on it?
Discussion in 'The Garage' started by mikey_d05, Jan 24, 2005.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Hi, the 14bff I have came off of a 1 ton truck so needless to say the spring perches and the shock mounts aren't in the right place. I pulled the shafts and took the hubs and drums off, should I do more than this before welding the new perches and mounts on? Also, I'm going to be running hydro assist on my front d60 so I'll be welding much closer to the differential than on the 14 bolt, should I remove parts from the differential itself or will I be fine? Thanks for any help.
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I diddent take anything off my 14ff when i did my perches, seems fine to me
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I have welded perches on a complete axle also.Your not gonna hurt anything :D
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Only issue you would run into would be arching in the lash of the gear teeth. To make sure you have NO issues keep the ground as close to the area being welded as possible.
