How far to move it back?
Discussion in 'The Garage' started by sapper, Oct 19, 2005.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Its just about time to start tearing into the truck for "winter mods". One thing I am going to do is put in a set of 56" springs in the back. I want to move the axle back to improve wheel base and departure angle but not to sure how far back would be just right. I have a zero rate in the rear so I can run the springs fowards and move it back 1 or 1.5 inches, or i could run the springs reversed and have the axle pushed back 4 inches, or 3, and 2.5 with the zero rate going one way or 5 and 5.5 with it going the other way. What do you guys think?
  2. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    where is your gas tank?? if your gas tank isnt in the stock location or you dont mind moving it id save reverse the 56'' and have the zero rate move them back another 1.5'' try to get as much departure angle and wheelbase as you can. ur probably gonna need a longer d-shaft.
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    ive mounted my 63's using the stock front hanger and moved the rear hanger all the way to the back of the frame. got about 5.5 inches of wheel base, and will require the gas tank to be moved. it might could clear a 10 bolt but not a 14. also, the way that my 63's are mounted, i dont think that i gained much if not anything in departure angle. but would prob. be alot better with 56's
    lots of cutting will be needed to give the tires room to move at this point. (5.5 inches back).
    if you dont want to cut too much i would try to stay around 1.5-2.5 inches.
    thats what mine looks like in the back with 5.5 inches back. sorry for the pic quality, but thats all i've got right now.
    ryan
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Post up a side shot of your truck. I know it's gotta be functional but it has to look cool too :D
  5. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    this is the only other one ive got right now
    the lighting in here stinks.
    found another. heres where i plan on cutting more or less.
    ryan
  6. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    your departure angle is terrible.
  7. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    its not that bad just as good as stock, will get better with bigger tires, prob gonna switch my three leaf 63's for a set of four leaf 63's or a set of 2" TC 63's and prob a shorter shackle. still figuring it out.
    ryan
