How fast is safe?
Discussion in 'The Garage' started by chriskh, Aug 21, 2006.
  1. chriskh
    chriskh Registered Member
    Jul 10, 2005
    31
    Castle Rock, CO
    After installing my tach, I notice at hwy speeds 70-80mph, I'm running over 3k RPM's. Is this safe for long distances on this motor? It's got a 350, 4bbl, 4x4, 4spd granny low tranny. I know the tach is right just from the sound of it as well as the fact that when it's idling, the tach reads right on the money.
    I will be driving this thing a lot pretty soon and I drive from Castle Rock to Colorado Springs and back all the time (approx 35 miles) where the speed limit is 75mph. What do you guys think? Anything to worry about?
    Thanks!
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    At some point, under high RPM and light load (highway cruising with low gears), the pistons etc. start to become unstable and the piston skirts can rub the cylinder walls. If you listen you can probably hear the motor making a cyclic sound. I don't cruise with mine above 3K.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Your profile says you have 31's , drop some 33's or 35's on it since you have the gearing to carry the taller tire . Your cruise rpm will drop :thumb:
  4. chriskh
    Jul 10, 2005
    31
    Castle Rock, CO
    Cool, I was thinking that might help too. It's gonna need new tires soon anyway so I'll probably grab a 4" lift and throw on some 35's at the same time. I would think that should reduce it at least a few hundred RPM's, no?
  5. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    its the speed limit, not the minimum speed.
    3000 RPM on a SBC is OK, from what I recall... the problem is if your doing it without any load-
    No overdrive?
  7. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Yup I'm in the same boat as you. I have the 465, 4.10 gears, and 35" tires. 75mph for me is about 3000rpm. I am no problem winding the thing up to 3500rpm and crusing there at about 85mph :D. I have done that 4-5 times recently for about 1 hour 15mins at that constant rpm. Afterwards just be mindful that your oil pressure drops below normal once you get back to idle because of the heat thinning the oil out a bit. That happens on all small blocks.
    The day or two afterward the engine ran smoother and more powerfull, probably because that rpm for that long must have dislodged some carbon deposits. :dunno: Who knows.
    Also if you are afraid of winding up the engine like that just think if that engine were in a boat it would see that kind of extended high rpm use just for cruising.
    Acording to that gear calculator, I guess I've taken my truck over 100mph before. :eek1: :eek1: How about that for a 305? :p:
  8. jonny290
    jonny290 Registered Member
    Aug 1, 2006
    19
    fayetteville, ar
    <--noob with a noob question
    Do 4x4 guys pretty much throw speedo calibration to the wind and ballpark it when you start tweaking rear end ratios and tire sizes? I'm comin from the ricer scene (don't ask) and they can get real fidgety about their speedo gears. Wondering if you guys try to match it up or just say screw it...
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i didnt mess with mine, but when i changed ratios, i did it based on tire size, so the speedo is only off by a little bit (i think mine reads fast by about 10%). if you how far off urs is then ur fine.
  10. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    speedo? What speedometer?:rolleyes: I only use my tach. No gear in my t-case. That or just follow the flow of traffic, maybe a little faster
  11. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    I know this is a rookie question but: I have a 700R4. Where this calculator asks for top gear, what would I enter here?
  12. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    put in .70, thats for the overdrive that trans has. I like some of these calculators too..... www.4lo.com
  13. chriskh
    Jul 10, 2005
    31
    Castle Rock, CO
    Thanks for the input guys. It's pretty helpful. :waytogo:
  14. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    My speedo cable is way off. That is until it melted on my exhaust. So for about the past year I have been using my tach to go by. My tach once broke too so I just had to guestimate.
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    With a 700r4 , 3.73's , and 35's , I cruise around 2100 rpm @ 70 in overdrive . Was under 2000 rpm when I had 33's . I hardly , even in mountainous driving , ever see 3500 rpm at all regardless of gear . I think everyone needs a 700r4 . And the convertor makes wheeling awesome at idle speeds :D
  16. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    I have a 350 with a 700R4 (86 K-5) with 4:88's and 35's and it cruises at about 3000 on the highway. I do a lot of driving with it especially from florida to tennessee and back. Is this bad? When I do downshift for grades it can get up to 4000 RPM's???
  17. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Sheesh, everyone needs to relax. Some of you guys are WAY too worried about revving your motors any higher than idle. :rotfl:
    The engines in our trucks were designed to be able to run at 3000 RPMs steady for hours at a time, with no ill effects. Shorter periods at 4000 RPMs(like when passing or climbing a hill) are not unhealthy either, as long as your fluids are in good shape.
    I'd LOVE to watch some of your guys reaction when I run my 5.0 Mercruiser up to 4600 RPMs for 5 minutes at a time out on the water. :rotfl:
  18. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i used to wind my 355 to 5800-5900 all the time, cast crank, stock but played with rods. :crazy:
    never had any problem with it. i dont see why 3-4K is such a big deal to you guys.
  19. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Highway cruising in a full-size isn't exactly a really light load for an engine, unless you think it only takes a couple of horsepower to push one of these sleds torough the air at 70 or 80 mph. I wish it did, because we'd all get fantastic highway mpg, wouldn't we?
  20. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Yeah I said it before and I'll say it again, we all drive bricks.
