how fast will I be going
Discussion in 'OffRoad Design' started by robert26, Apr 24, 2005.
  1. robert26
    robert26 Newbie
    Apr 24, 2005
    porter, tx
    I am swapping a 241 for a 208, and I need to know if there is anything that I can do to hook up the speed sensor to the 208. Oh yeah, it's a '94 suburban with a 4L80 tranny. I also would like to know if this will affect the shifting of the tranny.
  2. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Why the hell would you swap out a 241 for a 208.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I agree, why downgrade from a 241 to a 208?
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    my guess is hes doing a SAS on a newer body truck using a chevy or dodge axle. and a 208 is easy to find.
    your best bet would be to find a np241 from a 90-91 blazer or burb to get the VSS back.
  5. robert26
    robert26 Newbie
    Apr 24, 2005
    porter, tx
    The search continues
    I appreciate the information, but it doesn't make me very happy. I thought I was done looking for parts. Oh well, that's just part of it, I guess. You were right, I am doing a SAS on my suburban, but I didn't use leafs like everyone else around me. I went with huge x wide airbags, and three-links front and rear. I have built a bunch of hot-rods and race-cars, but man these 4x's are alot more work. But anyway, enough crying, I appreciate it again.
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you may wanna check some junkyards for a 2wd 700r4 with a VSS, probably 90 on up. they were gear driven (just like the your 208) but have the plug in for the VSS. they should fit the 208, you may have to change to gear to get it right.
    i totally forgot about GM using the gear driven VSS. i know on some of the 700r4s, they didn't use the gear driven VSS. the easy way to tell is the gear driven has a big hole the same size as the one in your 208, the non gear driven ones have a small hole, maybe half the size or a little bigger.
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    That 700R4 VSS is good to know about. Otherwise, you might be able to get some kind of signal generator from an engine conversion company but that's all I know about.
