How good are these tires??
Discussion in 'The Garage' started by 84CUCV, May 6, 2006.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
  2. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    Not to sure about tires , but it might be worth it for rim . Can you go look at them ? Only about 1 hr from Del mem bridge .
  3. DirtyJim
    DirtyJim 1/2 ton status
    May 4, 2005
    665
    San Diego
    the tred patten looks decent
  4. cycologic
    cycologic Registered Member
    Jun 6, 2004
    60
    Roaming, Earth
    The description on the auction site is misleading. Those tires are not for military HMMWV use. They are used for Light Armored Vehicles (gigantic lug pattern). They roughly measure out to 38.7 inches diameter (new) and are about 11 inches wide. I picked up a set last week and they are very heavy. Hope this little bit of info helps.
    Cliff
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Those are well worn and pretty dry. Those tires have steel belts from bead to bead (just like big rig tires). They weigh in just under 200 lbs a piece. They are a decent tire but ride stiff (load range G) and don't squat at all even without valve cores in.
  6. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Agreed, look at the lug hole diameter. Those are waayyyyyyyyy to big for a 998 series. I think they are off of the NBC vehicles as said above.
  7. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK guys thanks for the replys. So iguess there not worth it. I tried.
