How hard are rear bearings to change?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Nov 14, 2003.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    I lost my book, but I am just wondering how difficult would the rear bearing be to change. I have done front and that is pretty easy. at a glance i am not seeing how to get past the back plate of the brakes. Any info would be great. I will buy the book this week.
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    if you have a press, EASY. if you don't, still not too bad but it will take MUCH longer.
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    From your profile I assume you have stock 10B axles and that you mean rear wheel bearings. (I don't know how a press will really help)
    You have to remove the diff cover, pull the cross pin, pull the c-clips, and pull the axle shafts. Then you just about need a 3 arm slide hammer to pull the bearings out of the axle housing. It is kind of a pain - but you get faster everytime you do it. The book will help. You can also check out www.autozone.com and look at their repair guides.
    /forums/images/graemlins/thumb.gif
  4. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    You can rent a slide hammer at O'Reilly's or Autozone, that is about the only special tool you need. They are easy to install in a 10 bolt (If that's what you have) Take the back cover off remove the pin that holds the C-clip in for the offending axle, remove the brake drum & axle, remove the seal, the bearing cleanup & do everything in reverse! Piece of cake! Good luck!
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    10 and 12 bolt wheel bearings are cake, 45 minute job, tops.. pull the cover, pull the cross pin bolt, pull the cross pin, push the shaft in, slide the cclip off, pull the wheel/drum/axle shaft out/off, remove the seal with a seal puller, and remove the bearing with a couple good shots from a slide hammer, install new wheel bearing with bearing installer or a 2x4 and a hammer, install new seal with bearing installer or 2x4 and hammer, reinstall axle shaft/drum/wheel, install c clip, cross pin and cross pin bolt, reseal cover, install cover, fill with fluid
