How Hard: driveway T-Case swap??
Discussion in 'The Garage' started by XHitman396, Nov 7, 2005.
  1. XHitman396
    XHitman396 1/2 ton status
    May 3, 2002
    620
    Broken Arrow, Oklahoma
    well im swapping a broken np208 t-case for a non-broken one in my stock '87. ive only done this with a full shop including air tools, tranny jack and pole jack. needless to say, a trained monkey would have had a chance. now i will have to go through great difficulty and waiting to get to use this same equipment, so how hard it it to swap with no air-power and only a couple floor jacks in my garage?? my main concern is getting the t-case up in position and mating it up with the tranny.. anyone know how much a 208 weighs?? or even a 241 for that matter??? appreciate it...
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Its easy, I seem to do it about once a month :crazy:
    Support tranny pan with a jack stand and a block of wood.
    Pull t-case crossmember
    Pull rear DS
    Drain fluid from t-case
    un-hook shifter linkage
    Take about the bolts that bolt the adapter to the t-case
    Hold t-case while doing this as it will try and rotate down
    Get a good grip on it and slide if off the output shaft of the tranny
    To put it back on just bench press it up there and rotate it till it goes onto the splines of the output shaft.
    Just reverse the said steps up top.
    It weighs around 80 lbs or so.
    But just wondering, if you have done it before what dont you know how to do??
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yea a driveway 208/241 swap is a peice of cake. i do it by myself all the time with no air tools or lift. the tcase is light at like 80 lbs.
    now a 203 or 205, you need a jack and a couple people just to get it up there.
  4. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    x2... those 203s/205s are heavy mo-fos. I don't care how much you can bench press, if you value your life at all, don't try to lay under a 203/205 and uninstall it by yourself. 208 is definitely doable though. They are actually pretty light.
    j
  5. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I think 208's and 241's are like 75-80 pounds. I just laid under mine and benchpressed it.
  6. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Like everyone else has said, not hard. I'm doing it myself right now...........
  7. XHitman396
    May 3, 2002
    620
    i know how, but i wasnt sure how difficult it would be hold it up there and get it into position withough a jack or anything, last time i just put the jack under it, undid bolts, slid right out. better to research now and be positive i can do it, than jump into it and get f*ed, like if it weighed 200 pounds or something.. thanks for the input guys...
