How hard is bodywork
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by WARP1, Jun 17, 2002.
  1. WARP1
    WARP1 Registered Member
    Apr 8, 2000
    63
    Omaha, Nebraska
    I have a 1973 Blazer that needs some bodywork. Basically every panel except the hood and passenger fender needs to be repaired or replaced. There are rust holes in the front kick panels (down by the feet of the front seat passengers) that also need repair. I have no body work experience or tools. If I buy a welder, an air compressor and read a good instruction book can I fix this? I took a welding class at the local community college. I am just finishing an engine rebuild project on my Mustang so mechanical stuff doesn't scare me.
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Sounds like you should be able to handle it just remember it's an OLD truck and if you want it to be perfect it aint gonna happen unless your rich... Start with the stuff you can't see like the floors . I did my driverside floor by removing the old rust putting down some rust eater painting it and then fabbing a piece of sheet metal outta an old hood and glued and screwed it , new carpet hides that....You can do it...You've already taken a welding class take a bodywork class.... /forums/images/icons/grin.gif Good luck
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Body work is not hard, providing you have the tools, time and especially the number one thing: patience. /forums/images/icons/wink.gif
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    I have usually found this to be true with rust repair. As bad as it looks, it will be worse when you start tearing it apart. familiarize yourself with what patch panels are available and a local sheet metal shop who will bend pieces for you can be a big help as well.
  5. COLLISION
    COLLISION 1/2 ton status
    May 15, 2002
    175
    Kelowna,British Columbia
    Get out the tools and go for it. just remember that what you see is only the tip of the rustberg. /forums/images/icons/shocked.gif Take pics and ask lots of questions. look below to see what you'll be enjoying.
