how hard is it to change a power window/lock setup?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jackedjimmy350, Jan 7, 2003.
  1. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    mine's gettin a bit tired and warn out...just curious?? /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thumb.gif
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check all your connections first. Weak voltage reaching the motors will make everything work in slow motion. But if you want to change 'em, the lock motor is easy to change. You can see it, reach it, unplug it, and unbolt it easily. /forums/images/graemlins/thumb.gif
    The window motor is a bit more work... It's riveted to the door. You have to drill out the rivets, unplug the motor (which you can barely see, let alone reach!) /forums/images/graemlins/wink.gif and then take the regulator assembly out of the door. Then you drill a hole through both sides of the regulator and insert a bolt through them, so that the spring doesn't slam the regulator to the full up position when you remove the old motor. /forums/images/graemlins/shocked.gif Install the new motor, remove the bolt from the regulator, put the regulator back into the door and bolt the motor in place with the new nuts and bolts provided in the box with the motor. The directions for everything are included with the motor. /forums/images/graemlins/cool.gif It isn't terribly difficult, you just have to take your time and follow the steps.
  3. dyeager535
    26,975
    Listen to HarrhyH3. The locks for sure don't tend to go bad, but with bad connections they can certainly act funny. Mine wouldn't lock/unlock with the bolts to the door loose.
    The power windows need the tracks and gears cleaned/lubed, and a lot of times the switches for PW and PDL themselves need to be cleaned up. (which is very easy)
  4. jackedjimmy350
    Oct 20, 2000
    3,141
    cool thanks guys /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
