How hard is it to convert from automatic to manual?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyblzr1977, Aug 5, 2002.
  1. chvyblzr1977
    chvyblzr1977 Registered Member
    Jul 18, 2001
    83
    Pissburgh,pa
    I have a 77 blazer with 350 automatic transmisson and i think the 203 transfer case.I wwant to put a sm465 and a 205 transfer case in it.I heard you had to change out rearends is this true anyways how hard is it for the do it yourselfer.Any info would greatly be appreciated thanks.
  2. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Never done the process, but I can tell you for sure you absolutely will not have to change out the rearend. /forums/images/icons/cool.gif
  3. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    if you offroad much, you'll want a hydro clutch which is more expensive. I just priced the swap and with buying the tranny, tcase, shafts, clutch, ect ect, I was going to be well over $1K. It'd be a nice swap, but not for that kind of coin. You might also try using the SEARCH feature on this board. You'll get tons of great threads without starting a new one. /forums/images/icons/grin.gif
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I made this swap well over a year ago. Costed me only a new clutch. I traded my th350/np205 setup for a sm465/np205 setup. No shaft modifications, it was the same length setup as my auto. Swapped everything in and bought a new clutch is all.
    Hardest part was getting the clutch pedal bracket in, after that everything was cake. Total cost = $65
  5. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Yes please do a search...I've covered this topic myself too many times.Basically it's an two day job,go "hydro" and pull the trans tunnel cover.Do a search then if you have any Q's I'd be happy to help.I did the same swap(sort of)..went fron a TH350/203 to an SM465/208.I needed new rear shaft.Mike
  6. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I just finished this swap last month.
    I went from a th350/203 to a
    sm465/203/doubler/205.
    I did the Hydro conversion.
    Rear driveshaft is the same length! WOOHOO!
    E.A.S.Y. My friend and I did this all in a weekend.
    It took two months to get all the parts together though.
  7. chvyblzr1977
    Jul 18, 2001
    83
    Pissburgh,pa
    Hey would you mind putting up a list of parts that i would need for it.Do you have to change steering columns
  8. bigjbear
    Feb 18, 2000
    13,971
    452
    Marietta GA
    No, extra shifters confuse car theifs.
  9. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    Off the top of my head...
    Flywheel
    Shaft bushing for manual tranny, this goes into the crank
    clutch
    pressure plate
    clutch fork and boot
    clutch pedal assembly
    clutch linkage (reason to go to Hydraulic)
    sm465 bellhousing for mechanical linkage
    sm465
    sm465 to your favorite transfer case adapter
    You might also want to get the crossmember. Apparently a 205s adapter bolts are 1" narrower than a 203s adapter mounting bolts.
    If you get a stock sm465 and adapter to a 203, and the 203, you will not need to modify your driveshafts.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Topoff and Krazie are good ones to talk to about this swap.
    Topoff did the hydro in the old style cab conversion and documented it well
    Krazie has great threads on this subject including some tranny work
    Leadfoot has good images of step by step 205 rebuild....
    there is a ton of great info here by tons of great ?members?(so what are registered but nonpaying people called now? just deadbeats? no wait freeloaders!) just use the search function I cannot think of any angle that hasnt been covered
  11. atome
    atome Newbie
    Jul 16, 2002
    Colorado
    I did it about 2 months ago.. pretty easy considering.
    I swapped a TH350,NP203 to a SM465,NP203,NP205.
    Almost everything lines up the same.
    Issues I've had are:
    -Hydraulic clutch from mechanical
    -Front drive shaft lengthened (due to double T-case setup)
    -I had 2 cross members and the primary one fit just fine, but the second one required a little grinding. (also due to double t-case setup)
    -Custom shifter for 2 T-cases
    That's it..
    As far as cost, depends what you can find.
    A used transmission will probably run you about $150
    Same with a transfer case
    Then it depends if you want to rebuild the items or not, rebuild kits are about $100
    The hydraulic clutch cost me about $150
    Of course the adapter to do dual t-cases is probably the most expensive.
    So the moral of the story is if you don't want or need the dual t-cases or a hydraulic clutch you can do it quite easily and cheap.
    Adam
    '75 383,465,203,205,1/2ton axles (I'm workin on it), 35's
  12. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    hee hee.. i bought a pickup (since I dont have a blazer) for $500 and swapped sheet metal!!!! NOW THAT IS EASY..
    anyway.. yall talk about a hydrollic clutch... Why? what are the benefits and any links to info on this stuff? I am getting ready to swap in a motor soon so I will be there anyway....
    last question..
    dual transfer cases... what does that do for you?
    is that only good for rock crawling?
    and I thought if you are in 4high you are in 4 high.. no matter how many trasfer cases you have????
    so someone give me an example of a truck with a smc465/np205/np205??? how would you operate it???
  13. Lazydog
    Lazydog 1/2 ton status
    Apr 17, 2002
    129
    Phoenix, Arizona
    I did it last year. I thougt it was as easy as replacing a clutch. I had to get new driveshafts.
    All linkage (except for the bracket that bolts to the frame) I got from junk yards. The bracket on the frame is rivited so I didn't attempt to cut it out. I bought one at my local Chevy dealer for $10. bucks.
    If you can wait, get the bracket the pedals bolt to also. You'll have to cut the automatic one to work, but it still sucks. It bolts in anyway. I scored one from a junk yard for $20.00.
    Also get the trans tunnel cover. It already has the holes cut so no modifications are necessary.
    Replacing the steering column is not necessary, however I did because I wanted the truck to look stock.
  14. dyeager535
    26,979
    Hyde. setup isn't affected by body flex (no linkage between the body and frame to bind or bend) and it's self adjusting as the clutch wears. It's a bit of a pain to bleed the slave cylinder, but thats the worst part...except FINDING the hydraulic stuff!
  15. TopOff
    Jan 16, 2002
    1,760
    Folsom, ca
    "Doubler" questions... go to www.offroaddesign.com
    If you don't rock-crawl, you probably won't want to double up a 203 and 205 transfer cases.
    If you DO rock-crawl.. why did you change your gears???
    Because you want to go slowly when going off-road. Slow = traction
    to go slow instead of going into 2:1 low range, you go into a 4:1 low range. Now that's slow.
    Although, I thought it would be slower with the granny gear.
    My super low is about the same speed as a lazy walk. /forums/images/icons/frown.gif
  16. khotmer
    khotmer 1/2 ton status
    Oct 23, 2002
    228
    columbus, oh
    i have a clutch pedal assembly if you still need one..
  17. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    if he dosent end up needing it...i know kidjethro is lookin for the clutch stuff /forums/images/graemlins/thumb.gif
