How hard is it to convert to a serpintine belt?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by LKJR, Aug 18, 2002.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    title says it all, hasn't someone done this? thinking my OBA setup might be easier since I would only have to mount the compresser in a fixed position and the idler/tentioner would take care of the tention issue.
  2. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    well for 500 and some change you can order all the brackets.comes with new waterpump alt and everything from Pace Performance...may be able to find it cheeper but thats the only one i have seen..but that gives ya a startin off point
  3. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    how about a salvage yard job? is that possible with an older engine? and adapting all the new stuff?
  4. Chaz88K5
    2,979
    Stockton/Lodi CA
    well you could but by the time you bought it all from thw wrecking yard it would cost more for the used stuff than it would for the new right out of the box /forums/images/icons/smirk.gif i have priced it out once already...it was goin to be in the 600+ area if i got it all used...
  5. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    what all would I need? and would it all bolt right up to a 71 engine? or are there holes missing
  6. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    I don't know how it would bolt up but there are a ton of 88-95 trucks with serpentine systems that I would think you could get cheap. This may be what Chaz was talking about being $600. I dunno. I've seen this in trucks before but I don't know if they swapped the whole motor or just the belt system.
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    check out my answer on your other question. and yes all the holes are there for the way i did it.
    nathan
  8. lizard
    lizard 1/2 ton status
    May 11, 2002
    114
    Tallahassee, Florida
    Anybody try the setup from the 4.3 v-6? It looks like a direct swap except for the crank pulley. I was quoted $50 for the brackets and pulleys from a 4.3. I think I can get it with accessories for $100 or so...
  9. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    Should work in theory, from what I've heard, (you know how that goes) it's all the same on the front end as a v8
  10. Chaz88K5
    2,979
    Stockton/Lodi CA
    thats what i got the price from a 89 to a 9? and all the yards around here thinks there stuff is worth its weight in gold so may be able to find it alot cheeper...but that was what i was quoted for used stuff /forums/images/icons/smirk.gif
  11. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Wow I never would have guessed that much. Our yards smash everything so quickly or they stack them on top of 20 other cars. The 4.3 is the same with 2 cylinders cut off the end so like said in theory this would work.
  12. Chaz88K5
    2,979
    Stockton/Lodi CA
    the local yards in stockton are basicly picked clean...so for anything worth buying i have to go up to the yards in sacramento...and most of them up there wont let you take the parts off yourself...you have to pay them to pull it off...thats why its so expensive /forums/images/icons/crazy.gif
  13. Supergas
    Supergas 1/2 ton status
    Oct 17, 2001
    161
    Texas Coast
    Vintage Air in San Antonio makes a serpentine belt drive kit. I do not know the cost, but it looks trick..
    www.vintageair.com
    Or do like I did and install a later model TBI 350 and get the serpentine drive and new compressor for free.... /forums/images/icons/cool.gif
