How hard is it to lower the radiator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by deek, Jun 8, 2003.
  1. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    I just got my 3"body lift on & the instructions called for lowering the radiator. is it needed & if so is it easy?
  2. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    just trim the shroud.
  3. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    When I got my K5 the previous owner had put a body lift on it and let the fan do the trimming for him. Probably not the best way to go about it, but it works....I guess. I wouldn't recomend it though.
    Kris
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    The instructions will tell you how to do it if you have the Performance Accessories kit...although, I think on our trucks, you have to trim the fan shroud instead.
  5. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    do you have the 2peice shoud or 1peice if you have the 2 go to the local hard ware store and get 3inches in washers or a coupling nut and 2 bolts
  6. marine_enlisted
    marine_enlisted 1/2 ton status
    Sep 29, 2002
    658
    Stafford, VA
    "3inches in washers or a coupling nut and 2 bolts "
    Can you imagine how cool the noise would be if those washers vibrated free and fell into the fan ? /forums/images/graemlins/thinking.gif
    Sorry manI just had to find a reason to use that cool new gremlin . /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  7. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    loctite...jbweld....mig welder... no more rattle.. lol
  8. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    hehe I understand but with locktite and/or lock nuts(the nylon kind) it should be fine BTW ive seen it done Or you could just use the coupling nut
  9. Magnus88
    Magnus88 Registered Member
    Dec 6, 2002
    50
    Nynäshamn, Sweden
    I did my 3" bodylift (Black Diamond) a couple of weaks ago. I have the 2 piece fan schroud and what i did was this: Separated the two pieces. Fabbed two 5" pieces of sheetmetal into 1+3+1" looking like --> I_I Then i put the thing back together with the new "spacers". The problem (i didnt think this far ahead /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif) is that i was forced to trim some of the bottom shroud to fit the trans cooling lines and the lower radiator support. All in all i dont know if it was worth the effort, but now its there so i guess ill let it stay.
  10. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so the shroud is still there.
    does it actually DO anything positive anymore?
    the chev mounts the engine so my=uch lower then the rad stock, so a 3" BL pretty much makes the fan useless IMO
