how hard is it to replace body mounts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 86badass, Apr 14, 2002.
  1. 86badass
    86badass Registered Member
    Jan 2, 2002
    17
    port huron michigan
    hi there,
    my 2 rear body mounts are shot on the drivers side.
    i have a shop ready to do t he work and the mounts are paid for, how long will this take?
  2. 86badass
    Jan 2, 2002
    17
    port huron michigan
    anybody
  3. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    I just had all the body mounts replaced on my 76, cost like $300-400. Don't recall exactly how much as I had other stuff done at the same time. But the shop guys said it takes a while to do, like a day, for all of them.
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    It took about 5 hours (to install bushings,and body lift). Had alot of help. The hardest part is getting the old bolts out. I was quoted $425 from 4 wheel parts if they did the work.
  5. I replaced all the body mounts on my Suburban, something like 24 of them. It takes a while, but its not real hard. You just have to loosen all the bolts on one side then remove the other. After that jack the body up off of the frame and replace.
  6. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    It is very simple. The only "hard" part is the actual elbow grease you have to apply. Is doing it yourself a possibility? You'll save at least 300-400 bucks I imagine. Be sure to also replace the bolts and if you will ever consider a body lift, now is the time to do it.
  7. MudbogAD
    MudbogAD 1/2 ton status
    Jun 29, 2001
    672
    Las Vegas Nevada, US
    Suburbans don't have 24 body mounts. They have 12. This is a simple project. Loosen all body bolts, jack driver side of body up and replace mounts, then do same for passenger side. Tighten bolts up and your done. I don't see how it could take longer than 3-4 hours.
  8. 12x2= 24. Are there not 2 at the same point in some areas?
  9. MudbogAD
    Jun 29, 2001
    672
    I thought you meant 24 separate locations.
