How hard is it to swap the front wheel bearings
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sammy, Jun 12, 2001.
  1. Sammy
    Sammy 1/2 ton status
    Dec 8, 2000
    250
    And do I need special tools?
    And by any chance, does somebody know the part numbers from Timken or anything for them? I want to do this job at once.
    BTW It is a 10bolter.
    "K5 Grand GT Blazer Silverado in the Netherlands."
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It is not too hard. You will need a spindle nut socket and a torque wrench.
    Tips.........
    After you get the nut off take the outer bearing out and put the nut back on. Than pull the rotor off quickly cetching the inner bearing on the nut to remove the bearing and seal. Be carefull nocking out the old races (I use a brass drift) so as not to mess up the hub. If you play in water now would be a good time to pack the bearings with waterproof grease. You also mite as well replace the seal because it is cheep and you will probally jack it up when you take it out.
    '71 Blazer CST with alot of rust
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    JLM104949
    Sorry menory anit workin today
