How hard is this to change?
Discussion in 'The Garage' started by SlicksInRain, Feb 7, 2007.
  1. SlicksInRain
    SlicksInRain 1/2 ton status
    Jan 7, 2007
    238
    Chicago, IL
    My turning siginal lever I think has had it. It hasn't clicked back from a left hand turn on over a year and now I really have to push hard to get it to stay up on a right hand turn so it's time for a change. I was thinking of going to a junkyard and getting one, but I don't know how to remove or install this thing. If theres replacement parts to stay up or click over I would rather buy that, but again do I need to remove my wheel for any of this? :confused:
    Thanks!
  2. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    Its pretty easy. Its controlled by a plastic "thingy" inside of the steering column. Just tear appart a steering column and you'll see it. Then carefully take it apart and do the reverse to your truck when you get home. I just did mine and it was the first time I pulled apart my steering column. I do suggest getting the specialty tool to hold the spring back so you can install the snap ring back on when re-assembling it. I made my own but I don't know the tooling you have available to you.
    ~Brian
  3. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    Your going to have to remove the wheel to replace that signal lever.
    EDIT: Im slow
  4. SlicksInRain
    Jan 7, 2007
    238
    Chicago, IL
    What about just for the "springy" things that catch the lever for a turn?
  5. Brians89K5
    Jan 4, 2006
    535
    Rialto Ca.
    Thats under the locking mechanism in the steering column. To get at that you have to take the steering column apart.
    ~Brian
  6. goldwing2000
    goldwing2000 Guest
    You can get new springy thingies and click thingies from any auto parts store that carries Motormite (HELP!) products. Alternately, you can order the stuff right from chevy duty or LMC. And all of them are under the lock plate inside the column.
    Right now Harbor Freight has a steering wheel puller/lock plate compressor combo kit for $13.99. It's only available in the stores, though. I couldn't find it online. Item 42031.
