How Hard is this to fix
Discussion in 'The Garage' started by mtnman210, Dec 13, 2004.
  1. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I'm really considering buying a 77 I've found for 1500. It has a fairly clean body which I was looking for so I can start a buildup. In the pictures is suppose to be one of the only bad spots the truck has. I've heard because it's inside the door frame it would be difficult to fix.
    Any thoughts on how hard it would actually be to fix the rot?
    http://community.webshots.com/album/231870948RYZXgF
  2. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I'd be very surprised if that's the only rot on the truck. Check under the carpets, check the rearmost area of the floor. Usually the tailpan rots out back there leaving the box sides weak.
    Pretty odd to see rust that high on the truck though, almost like it spent it's life close to the ocean.
    I would recomend taking a very critical look at it before parting with a single cent. As for how hard it would be to fix...it would be time consuming and difficult. I'm not even sure they sell patch panels for that far up the truck so you'd have to fabricate all your own patch pieces. Rust repair usually takes 3 times longer than you first figured and costs two to three times more than you first thought.
    Rene
  3. k5freak44
    k5freak44 1/2 ton status
    Jun 1, 2004
    2,164
    Plano, TX
    RUST IS FUNNNNNNNNNNNN
    if you have a welder, a grinder a cuttingwheel and some bondo you shouldent have a problem fixing it. the only thing i would be worried about is getting the pannels to fit back right.
    If i were you i would buy it, cut all that out and buy a softtop for a 72 model that goes all the way above the doors and to the windshield. Thatd be your best bet and fabbing something like that really isint that bad if you have all the equiptment
  4. k51989
    k51989 Registered Member
    Sep 19, 2003
    93
    Mishawaka, Indiana
    haha man thats not rust...
    'looks up at location'
  5. slyguy_22
    slyguy_22 1/2 ton status GMOTM Winner
    Dec 13, 2004
    789
    Lancaster, PA
    That is way too much for a blazer. Check around your area u should be able to find a good starter body solid floors and such, I live in the rust belt and i found a complete blazer with solid floors a carb 350 and th350 that runs for $300.00
    So I would think long and hard about spending 1500 on something u have to do a lot of work to. there are a lot of these blazers around and all of them are interchangeable. i should have some pics of the progress on mine up soon.
    The other thing to think about is how much can u acctually do ur self?
  6. vervepipes
    vervepipes Registered Member
    Sep 25, 2004
    20
    Alberta, Canada
    no kidding, i bought a grinder just FOR the k5. the first thing i didn was take off my running boards and cut off what was left of my rockr panels (didnt really need a grinder for that, i could poke it off with my fingers but the grinder gave it a "cleaner look" :)
    before it got too cold here i was outside every day grinding. i think i found a new hobby
  7. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Grinder is so noisy-
    Good thing home depot has these new "AM/FM" sound blockers. ;)
