how hard to change tranny mounts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by delta9blazer, Mar 29, 2001.
  1. delta9blazer
    delta9blazer 1/2 ton status
    1,646
    Northern California, over by 7-11
    my truck just got lifted 4", and 35's. now i notice my tranny jumping just a bit if i leave a stop moderately hard. you can see it move under load if you look.
    is this something that i'll be able to do in my driveway? my neighbor is a back-yard mechanic from way back, and i ain't asceered to get my hands greasy. it seems that it would be loosening a few bolts, supporting the tranny while the old rubber crap is removed and new mounts inserted, then lower and tighten.
    or am i simplifying it?
    thanks!
    <font color=purple>delta9blazer</font color=purple>
  2. lowlevell
    lowlevell 1/2 ton status
    Jun 27, 2000
    343
    Central Ohio, USA
    Block the wheels
    Set E- brake
    Put truck in nuetral
    Use a floor jack with a small 2x4 or 2x? to raise the tranny, or
    If you have a big floor jack, raise it at the xfer case.
    DO NOT raise it from the rear of the tranny! @ the rear seal
    Unbolt old mount
    Bolt new mount in
    Lower tranny back down and tighten bolts
    Put truck back in Park and remove blocks
    Go inside to the refrigerator and get a beer:)
    One From None
  3. lowlevell
    Jun 27, 2000
    343
    Central Ohio, USA
    Wait a sec,
    Your tranny is jumping? Did you shim the rear end when you lifted it? If not it may be binding. You can lower your xfer case to help some.
    One From None
  4. delta9blazer
    1,646
    and how is the lowering part accomplished? i don't mean to sound like an idiot, but i'm kind of an idiot.
    oh, and the mounts are visibly deteriorated. there may be some binding, but the mounts need to be swapped out, regardless.
    <P ID="edit"><FONT SIZE=-1>Edited by delta9blazer on 03/29/01 07:34 AM (server time).</FONT></P>
  5. lowlevell
    Jun 27, 2000
    343
    Central Ohio, USA
    You need to raise the tranny up with a jack to get the old mount out. After you bolt the new mount in, you will have to lower the tranny back down, then bolt it to the crossmember.
    One From None
  6. lowlevell
    Jun 27, 2000
    343
    Central Ohio, USA
    Do a search on this site to find out how to lower the tranny. It takes to long to explane it. Just click on the search tab at the top of the page and type in "lowering tranny" or "lowering tranfer case" or "driveshaft angles". Hope that helped.
    One From None
