How hard to convert 700R4 to floor shift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NewK5Guy, Mar 7, 2001.
  1. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    How difficult would this project be? This is an 84 K5. I'll assume I could use an aftermarket universal shifter which utilizes a cable. I could run the cable through the hole where the t case shifter is and mount the shifter pretty much anywhere on the tranny tunnel I want(just make sure the cable don't bind). A longer handle would be required as well. Thoughts? Opinions? Testimonials?
    <P ID="edit"><FONT SIZE=-1>Edited by NewK5Guy on 03/07/01 02:29 PM (server time).</FONT></P>
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I doubt it'll be worth it. Why do you want to put it on the floor anyway?
    [​IMG] Keep your feet dry [​IMG]
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  3. dyeager535
    26,978
    Not only not worth it, then you somehow have to leave the column shifter connected for reverse lights and neutral start switch. Just leave it where it is IMO.
    Dorian
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I dont think it would be hard at all, I am thinking about doing it too because I am getting a tranny with a manual valve body and its too easy to go into neutral when you are power shifting. I will be removing the center conslole and I will prob fabricate a smaller one placed back a little farther. B&M makes the truck shifter that sits a little taller than the standard shifter and it comes with the reverse light swith and I think it may come with the shifter cable too. If I do it ill let you know how it works.
    Brent
    PS its the B&M mega shifter I think...
  5. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I'm gonna do this to my new truck. I already have a light truck megashifter to go in. I originally got it to go in my 87 because I couldn't get to 1st gear due to the body lift screwing up my linkage. Anyway, it's just a nice addition, but is somewhat meaningless unless you're going to go with a manual valve body. I don't like the column shift and linkage.. I feel the cable shifter will work better.. not to mention it has relays to hook up the reverse lights and neutral saftey switch. It's just a $160 replacement for the column shifter.
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
    If it ain't leaking oil, it ain't my truck![​IMG]
  6. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    Already did it the only problem was the box that covers the shifter had to be trimmed. It cover the 2 Hi/4Lo/4Hi . No big deal though.... Reverse light works no problems.. I have a Quicksilver in mine...
    Eat More Mud!!!!
  7. NewK5Guy
    Mar 2, 2001
    556
    Alexandria, VA
    Hmm...3 for/2 against. I want to do it because not only does it look cooler, but the shifter in my truck is vauge and seems to have 2 neutral detents with one seeming to move around. I took a look at the shift linkage and there must me a million parts. A cable shifter would certainly lower the amount of part numbers there and help in the dependability dept. I'm still gonna look into it.
