how hard to do 203 p/t conversion?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Feb 9, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    How difficult is the prt time kit to put into a NP203?
  2. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    I did one last year! takes longer to unbolt the housing then to actually put in the kit. Im pretty sure we did it in less the 45 min, start to finish!
    hope that helped!
    Bigmeats.....Manhattan Il
    1975 Blazer
  3. reddog64
    Nov 9, 2000
    3,325
    what is involved... brief rundown?
    -Red
  4. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    Which one are you going to do? the shaft kit or the spider gear kit?
    *wink*
    my 79 rust bucket will run over your 2001 chevy 4X4 tahoe plastic wagon
  5. reddog64
    Nov 9, 2000
    3,325
    difference?
  6. Redfrog
    May 4, 2001
    753
    IL
    look at this it should tell you what you want to know,
    I did the shaft conversion it was easy but if you do it you need to get a new oil pump gear from GM they are like 6 bucks hope this helps
    <a target="_blank" href=http://www.off-road.com/chevy/mm-np203/>http://www.off-road.com/chevy/mm-np203/</a>
    *wink*
